Old 03-26-2020   #1
Corvette95
Corvette95's Avatar
Default What all to remove on the throttle body for powder coat?
Does the entire TB need to be bare for powder coat? Seems pretty delicate. Is there a how to? I searched for solutions. What all comes off? Any tips?
Thanks
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 03-26-2020   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: What all to remove on the throttle body for powder coat?
I strip them all the way down.
There is a nylon bushing under the primary return spring that can’t take the heat. Be sure to Dremel off the spot welds on the end of screws that retain the throttle blades to the shaft so you don’t wipe out the threads.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-26-2020   #3
Jagdpanzer
Jagdpanzer's Avatar
Blade screw ends grown down.
Nylon bushing
Good time to replace the secondary stop screw with a hex head to make it easier to adjust
Bare TB
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-27-2020   #4
cvette98pacecar
Attachment 11602
Attachment 11603
Nylon bushing
Attachment 11604
Attachment 11605
Bare TB
Phil, Speaking of TB. I still have two to send you. No rush I have plenty of other projects.
Old 03-27-2020   #5
Corvette95
Corvette95's Avatar
I am down to removing the blades - I can reach the rear of the blade screws in the two large ports, what about the small port on the bottom, is that supposed to be dremeled too? I don't have an attachment that will reach into the small port for the small blade.
Old 03-27-2020   #6
Jagdpanzer
Jagdpanzer's Avatar
Remove the stop pin inserted into the primary throttle shaft which will allow you to flip the small blade over and get at the screw ends from the front side.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-27-2020   #7
Jagdpanzer
Jagdpanzer's Avatar
I’ve been expecting them Robert.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-13-2020   #8
jss06c6
Agree with Phil. Full disassembly before powder coating..
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Old 05-13-2020   #9
jss06c6
Top end powder coat.
Old 05-13-2020   #10
32valvesftw
Damn Steve thats Georgous!
