Old 03-23-2020   #1
32valvesftw
Default Quickjack question
Quickjack users, are you lifting your ZR-1 with the rubber blocks that came with it on the body seam? Or do you use the accessory blocks that can be purchased that have a cut out "V" for the seam. I know many of you use QJs, and I have not heard about issues with the stock blocks but I wanted to check.
Old 03-24-2020   #2
Default Re: Quickjack question
Rubber blocks and in my case they go under the heim joints for the V2V No Flex.
