![]() Join Date: Mar 2020
1G1YZ22J5R5800084
can anyone determine color from the number? |
No, I don't believe one can. That VIN looks to be a 1994 red Z with black interior
![]() Join Date: May 2007
I agree... 1994 Torch Red with Black Interior
In 1994, GM made 65 Torch Red with Black Interior ZR-1's. Jim Last edited by QB93Z; 03-16-2020 at 02:25 PM. |
Great
Thanks! |
![]() Join Date: Nov 2018
Open your door on the center console you will fine the Service Parts Identification label and you will see your VIN @ the top and all codes pertaining to your car below the VIN.
At the very bottom you will see the Base Coat/Clear Coat Code. |
Awesome..thank you so much!
Noooooooooooooo!!!
Thank heaven |
#9 |
The VIN tells you its a ZR1, body coupe or convertible and engine. Check the NCRS Manual for a breakdown. If you have a sticker on your center compartment lid it will say the interior and exterior color, if its gone get a build sheet from the Museum.
#10 |
![]() Join Date: Nov 2007
Cut n paste this for your file
![]() If the EIGHTH character is an "8", it denotes an L98 Last edited by Paul Workman; 03-29-2020 at 07:40 PM. |
