03-10-2020 | #1 |
Fan won’t shut off
Took my 1991 out last weekend on a bumpy road. When I got back and parked the car my fan kept running after the car was shut off. Left it thinking it will cool and shut off. Today it had a dead battery. I jump started the car and drove it for about 15 minutes. The fan turned on immediately when the cables were hooked up and continued to run after the short drive. When I went to disconnect the battery I noticed the negative battery terminal was loose. I will try recharging the battery and tightening the battery cables. Anyone ever had an issue like this? The fan that runs seems to be the blower fan for heating and cooling.
03-11-2020 | #2 |
Re: Fans doesn’t shut off
Hello,
Here is a link that may help. Good Luck, Bill http://www.zr1.net/forum/showthread....ghlight=blower
LT5 Red/Red |
03-11-2020 | #3 |
Efnfast, this sounds like the problem you had?
How did ya resolve it? |
03-11-2020 | #4 | |
Your Post above now in -Solutions- ....... See -Solutions- Post 7 - ZR1 Specifications, Restorations, Air, Bose Audio, Lifts (AIR CONDITIONER & HEATER).
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-12-2020 at 02:19 PM. |
