Old 04-10-2007   #1
Artic93
Artic93's Avatar
Default Hose routing question on a 93
My car was built in January 1993 , I have a hose routing piece of plastic attatched to the fan shroud that looks like the LT1 set up. Should my hoses be running through that area? The closest hose does not seem to be able to fit on that angle. The car has had no accidents according to PO and carfax so I'm puzzled. I'm attaching a pic of my spot in question and also a pic from HilKing's 93 which looks to have the same piece of plastic ,but being used by a hose. Any light on this subject I would appreciate.
jason
93 Artic/Black 14K #189
Artic93 is offline   Reply With Quote
Old 04-10-2007   #2
Jeffvette
Default Re: Hose routing question on a 93
No, it should not be running through there. That is for LT1/4 cars only. It shouldn't be in your engine bay in the first place.
Old 04-10-2007   #3
Artic93
Artic93's Avatar
now I'm confused....
Old 04-11-2007   #4
Artic93
Artic93's Avatar
Are the correct fan shrouds still available or is the plastic routing a removable part?
Old 04-11-2007   #5
zr-1assassin
zr-1assassin's Avatar
here is a pic of an lt1 and you can see its on there?????????
zr-1assassin is offline   Reply With Quote
Old 04-11-2007   #6
zr-1assassin
