Old 02-07-2020   #1
whale
Default C Beam Plates
Does anyone still offer these plates ? Thanks Wayne
whale is offline   Reply With Quote
Old 02-07-2020   #2
Default Re: C4 Beam Plates
C4 Beam Plates
Definitely an improvement if you have ever removed a Transmission and noticed the countersunk area around each of the two forward and two rearward C4 Beam Bolts. This indicates the compression load on the aluminum is too concentrated without the use of a much larger washer (top and bottom Forward and Rearward).
The "Washer" (C4 Beam Plates) not only offer a larger area spreading the bolt tensile loads but the C4 Beam Plates are stiffened so they do not flex themselves (or Five Stars).
Old 02-07-2020   #3
secondchance
Default Re: C Beam Plates
I would contact Bill Boudreau.
http://zfdoc.com/c4beamplate.htm
Old 02-07-2020   #4
whale
Thank you they are on their way.
