Old 04-09-2007   #1
zr-1assassin
zr-1assassin's Avatar
Default which tops do the z take???
can someone tell me if the z's take the same top as the ordinary c4's? i have a 90 and am looking to buy the transparent top, but i dont know if the wide body affects the tops. help!
zr-1assassin is offline   Reply With Quote
Old 04-09-2007   #2
tccrab
tccrab's Avatar
Default Re: which tops do the z take???
A standard C4 roof panel will fit a ZR1.
There are two colors of transparent roof panel, bronze and blue. Be sure to get the right one for your year. Also, the later year Z's had the car serial number stamped on the roof panel.
Old 04-09-2007   #3
Bell Curve
Bell Curve's Avatar
Yeah any C-4 will fit so try and get a newer one if you can find it or just buy a new one.
Bell Curve is offline   Reply With Quote
Old 04-09-2007   #4
zr-1assassin
thanks for the info guys!
Old 04-10-2007   #5
Artic93
Artic93's Avatar
where exactly is the serial # stamped on a 93?
Artic93 is offline   Reply With Quote
Old 04-11-2007   #6
blackjack
i alwaye tought the tint in the clear top was related to the body color ??
i have a 91,and my clear top is tinted blue...am i ok?
bj
91/1735
Old 04-12-2007   #7
TeK_NoiR
How much does a used C4 top usually cost ?
It`s said to be a transparent one is much cheaper than a solid one ?
TeK_NoiR is offline   Reply With Quote
Old 04-14-2007   #8
Z Factor
Z Factor's Avatar
It really varies based on the condition of the acrylic glass panel (or paint on the sold top), and yes the solid typically costs more.
I've seen the used clear ones go for as little as $200.00, but most are in the $500.00 range. You can actually send your existing one off to have either the bronze or blue refurbished if yours is damaged or not to your liking cosmetically.
BTW- Is your name a reference to the club in the movie the Terminator, music, or something else?
Old 04-15-2007   #9
actuary67
If you have a rebuildable exchange, then as low as $479 (through Thompson Astro Tops).... on the advice of others on this forum, I went through Melrose T-Top ($799). Melrose let me keep my factory frame (stamped with VIN #) and they did a GREAT job. I believe that the most expensive option is to go through GM ($1,295), and it's my understanding that they don't let you keep your frame (according to the local dealer).
Regards,
Steve
1992 ZR-1 #202
black/black
actuary67 is offline   Reply With Quote
Old 04-16-2007   #10
TeK_NoiR
Ok tanx steve and Z factor, good to know. Fortunately I got both tops with my Z.
Yes, well recognized, "Tek Noir" is a reference to the club in Terminator 1. I love this movie and its style - and also of course the multifacted 80`s.
There is also a fameless band named "Tek Noir"
