Old 01-28-2020   #1
32valvZ
32valvZ's Avatar
Default Steering Column Swap
So i am considering a swap because of a real sloppy tilt. I figure its just easier to swap rather than rebuild mine. I have a line on a rebuilt one, just need some input from you guys.
VATS is bypassed on my car by the P.O. I dont know what method he used to accomplish that. He did say a key without a chip would work in the ignition due to the bypass. Will I have any other VATS complications?
Im concerned with the clock spring and air bag. Never fooled with one in any kind of car.... What precautions are there and what should I expect with these things?
Thanks in advance
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 01-29-2020   #2
Default Re: Steering Column Swap
You need a VATS bypass on your car side harness...
As for the Clock spring, when you remove the steering wheel I usually ziptie the clock spring so it does not move
I can get more info as you need it.. I am at work and figured I would answer quickly
Old 01-30-2020   #3
Isn't the "real sloppy tilt" related to wear on a pin in the column? If that is correct, I think Marc Haibeck has a solution to that short of replacing the whole column. You might check in with him. --Bob
Old 01-30-2020   #4
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Typically, you need to replace the column support, some call it a knuckle, the two pins, a spring, bolt with retainer.
All of those cost under $200.00 with shipping.
You need to take the wheel and air bag off either way, and that is where you most need to be careful.
To replace the above parts is not really that complicated, just take your time.
The more pictures you take at each step will help you get it back together.
I would not waste the money or time trying to resolve all of the added problems of swapping columns.
GM should have put a big NO TOUCH WHILE EXITING! on that wheel.
I always tell C-4 folks to grab the A-post and NOT the wheel to hoist themselves up.
When I look at an incoming C-4, reaching in and gently tugging the wheel to the left is one of the first things that I check. More then 25% show wear.
Keep us posted.
Marty
Old 01-31-2020   #5
this is not exactly like ours.. but close and a good reference
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Old 02-01-2020   #6
Andy
Don't know about now, but the place below
Steering Column Services
889 Molinaro Ct
Ivins, UT 84738
used to have some nos and also reconditioned knuckles for our cars. Pricey, though.
1990 black on black #1042 - sadly - sold
1993 Ruby #140 - stock
1991 QB #1608 - heads and top end ported, Watson headers, B&B 3"exhaust, Haibeck chip, 4.10 gears
Andy is offline   Reply With Quote
