01-21-2020 | #1 |
Pete's Handy Work
Got my intake and injector housings back today. Cleaned them up tonight and installed the IH O Rings... Its a shame nobody will be able to see Pete's porting job. Thanks Pete... Cant wait to get it all back together... hopefully this weekend.
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
01-21-2020 | #2 |
Re: Pete's Handy Work
A few more
01-21-2020 | #3 |
You’ll be sending ur cylinder heads to Pete next.
01-22-2020 | #4 |
I am well aware this is a slippery slope.... I'm hoping this combined with a 4:10 rear gear will satisfy my needs... hoping...
01-22-2020 | #5 | |
God that’s funny!
01-22-2020 | #6 |
After the heads comes the cams swap....
That is some beautiful porting work!
91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
01-22-2020 | #7 |
Pete's top-end porting, AND 410s! It will be a totally different animal! You won't believe the difference, the first time you "whack" it (as Pete says!).
This is how the LT5 should have come from the factory. I think that is safe to say, looking at the gen-II and then the gen-III versions. Without cams or TB porting, mine dynoed at 432 rwhp (approx 508 @ the crank) without changing the stock idle or mpg, up from ~327 wheel hp stock. That's quite a trick - and testimony for Marc and Pete as to some of the advantages of the DOHC platform.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 01-22-2020 at 09:24 AM. |
01-22-2020 | #8 | |
Where are we sourcing them nowadays and what do you have to do to recalibrate the speedometer?
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker Last edited by billschroeder5842; 01-22-2020 at 10:45 AM. |
01-22-2020 | #9 |
My '93 has a Dana 4.09 gear. Came that way when I got the car.
I believe you need to change the speedometer gear in the transmission to re calibrate. Not 100% sure on that.
01-22-2020 | #10 |
I'm interested too. Talked to Steve @ Crossed Flags, and he only recommended up to 3.90s as he no longer has a good source for the 4.10s. And yes, you have to change the speedo gear to correct for the rear gears. I know Haibeck lists them.
Evan
2024 Z06 SOLD - 1991 Admiral Blue ZR-1 SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP SOLD - Steel Blue 91 391cid ZR-1 #391 SOLD - Black 91 ZR-1 |
