Old 01-14-2020   #1
32valvZ
32valvZ's Avatar
Default Fuel Rail O Rings
Are the ones inside the fuel rail, (there are 4) the same as the rest? I got Jerrys O ring kit and have 4 that I cant see where else they go...other than inside the fuel rails...
https://www.jerrysgaskets.com/seal-s...n-90-95-7-5d8/
Thanks, John
Old 01-14-2020   #2
jss06c6
Default Re: Fuel Rail O Rings
What year is your ZR-1?
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Old 01-14-2020   #3
Ccmano
Since you have a 90’ you should have the 2 different sizes for the injectors themselves. 8 larger for the Primary Injector lowers that mount into the injector housing itself. 24 smaller for the 16 upper of all injectors and 8 lower for the secondary injectors. Then a smaller set of 2 for the fuel line to the fuel rail connection. These last ones are also used for the pipes, rails and regulator connections. That’s probably what your seeing.
H
Old 01-14-2020   #4
32valvZ
32valvZ's Avatar
So Phil rebuilt my FPR... I had Jerry send me a FPR O ring kit... this is not for injectors.... only the lines that go to the FPR.... Theyre all the same size. Inside the actual fuel rails, there are O rings... I wasnt sure if theyre the same as the ones where the lines plug into the FPR. I have 4 left and there are 4 bores, 2 in each rail that have O rings inside them...
Old 01-14-2020   #5
Ccmano
Yes, I believe all the fuel rail o-rings are the same size. I believe there are 9 total O-rings for the rail/regulator.
H
Old 01-14-2020   #6
32valvZ
32valvZ's Avatar
H
I was skeeered to pluck them out of the rail with a pick and ruin them if they were different...
