Old 12-25-2019   #1
wutanec
Default Injector Housing Gasket Replacement
Hello y’all. Merry Christmas! With all the holidays until next year. I am about to tackle replacing the injector housing gaskets which I have been long suspecting of leaking coolant for a while now. It seems like there are plenty of how-to’s on removal of the plenum but I have not found too much info on removing injector housing. Any do’s and don’ts specific to removing the IH? Any help would be super appreciated. Thanks!
wutanec is offline   Reply With Quote
Old 12-25-2019   #2
G8nightman
G8nightman's Avatar
I would get new injector o rings and don’t try to remove the coolant tube from the IH the bolts will crack. I would also get everything powder coated while it’s out. Once the plenum is out the IH are straight forward.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 12-25-2019   #3
wutanec
Default Re: Injector Housing Gasket Replacement
Thats a great point about not removing the coolant tube from IH. I am not ready to buy a new set of IH lol. Speaking of coolant, is it necessary to drain all the coolant from the car?
Old 12-26-2019   #4
G8nightman
G8nightman's Avatar
No drain about a two gallons should be enough.
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 12-27-2019   #5
wutanec
So I finally took the plenum off tonight. The process has been less painful than expected but I had a couple of oopsie moments. I will tackle IH tomorrow and see how that goes.
Now here are my newbie mistakes.
* While removing the connectors in the rear bottom side of the plenum, I broke one of the clips while trying to pull it out........which connector is it and is there a way to purchase a pig tail version?
* While pulling wires off of injectors, I did not realize there were little orange gaskets to the connectors, I lost one of them. I just ordered a few from Jerry's but now I am paranoid that it might have fallen into one of the ports....will I be able to see it once I take the IH's off? if not, I assume it will kiss the engine good bye yes? lol
* I tried to pull off the injectors..It seemed like the secondaries are loose but the primaries would not budge...any tips on how to remove those suckers?
Thank you.
Old 12-27-2019   #6
G8nightman
G8nightman's Avatar
Jerry should have everything you need and you should be able to fish it out here is what it looks like with everything offIMG_7883.jpg
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 12-27-2019   #7
RussMcB
*If* you are really concerned the little orange rubber thing dropped somewhere, use your shop vac to suck out from the ports, and maybe through spark plug holes. Maybe empty the shop vac first so you can see what got sucked up.
My first thought was don't worry about it. Maybe it's unlikely it will lodge itself somewhere it will do damage. But, others more knowledgeable may have a better opinion about that.
Good luck.
Old 12-27-2019   #8
Ccmano
When you say your replacing the IH gaskets are your doing the upper (considered the plenum gasket), the lower or both?
Are you replacing the injectors as well? If they are original now is the time to do it. Original injectors in 90-92 models are either bad or about to go bad. No matter what the mileage. They were not designed to tolerate the ethanol in today’s gas and corrode from the inside. Replacement is highly recommended. To remove the stuck ones just grab by hand and twist. Keep twisting back an forth till they come out. A really bad one may require some help to start the twisting. I spray some WD40 on the base and use a long and large pair of L head needle nose pliers wrapped in a shop towel to carefully twist a few times. Then twist by hand to remove.
H
Old 12-27-2019   #9
Post 150 - How to Remove Injector Housing Coolant Manifold Torx-30 Bolts
Old 12-29-2019   #10
Jerrys Gaskets will have the new O-rings for the injectors. Only the 90 ZR-1s have upper (injector) body gasket O-rings on the PRIMARY injectors only. The rest are sealed at the tip. (Jerry knows exactly what you need - just tell him the model year. And, he can set you up with new injectors too, if need be!)
Far as the IH goes, all that may be needed is to re-torque the bolts holding it to the block. A couple of mine were barely finger tight, first time I pulled the plenum! Also, some BLUE LOCKTITE thread locker on those bolts will keep them from loosening up again.
And, just a suggestion too.... unless you drive you car in sub-zero weather, you can BLOCK the coolant ports leading to the plenum by drilling and taping the holes and inserting a (screw-in) plug. Then the next time you pull the plenum, you won't need to worry about draining the coolant! (Mine have been blocked for at least 10 years now, and not a whit of trouble! 'Course I don't drive it in sub-zero temps either!)
And, here is a link to Del City which carries just about all the connectors (with maybe the big one attached to the Digital Ignition System (DIS) module).
