Old 12-23-2019   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Winter Project - Suspension Upgrade
Decided it was time to replace the 26 year old rubber suspension bushings and install DR trailing arm and camber brackets while at it. Went with SuperPro bushings all the way around. https://www.corvettepartscenter.com/...erpro-c4-84-96
These are one piece design bushings which are not nearly as stiff as the other urethane bushings out there. And they come with a lifetime warranty.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-23-2019   #2
RICKYRJ1
RICKYRJ1's Avatar
Default Re: Winter Project - Suspension Upgrade
WARNING!!!!!! Please wear eye protection before viewing these photos! That is some nice bright polished metal. Job Well done grasshopper.
Old 12-23-2019   #3
Phil,
Did the DRM brackets a couple of years ago. Nice.
Old 12-30-2019   #4
VikingTrad3r
Jag d have u read any reviews of the superpro set on the c4? They sound perfect.
VikingTrad3r is offline   Reply With Quote
Old 12-31-2019   #5
Flyman 27
Flyman 27's Avatar
How did you get the suspension components so clean? What process did you use? Nice job, BTW.
I have heard good things about the super pro bushings. Please let us know how it goes.
[SIGPIC][/SIGPIC]
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 12-31-2019   #6
rkreigh
Attachment 10975
Attachment 10976
take a look at the banski rods with the boots over the spherical rod ends. work really nice and take a lot of hassle out of the rear.
Old 01-20-2020   #7
That’s what I use. Boots and all. GC
Old 03-14-2020   #8
UnderPressure
Any follow-up with the SuperPro bushings? how was the fit? the ride? do they squeak? I'm starting to gather parts to overhaul my suspension soonish
UnderPressure is offline   Reply With Quote
Old 03-15-2020   #9
Jagdpanzer
Jagdpanzer's Avatar
Car is still up on the lift in winter hibernation. Besides the SuperPro bushings also upsizing the exhaust piping to 3”. Should make its spring outing first week in April.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-24-2020   #10
Jagdpanzer
Jagdpanzer's Avatar
Installed urethane lowering wedges on the front spring seven years ago. Found this when installing the new suspension bushings.
Can anyone recommend wedges that hold up better?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
