Old 12-17-2019   #1
Subfixer
Subfixer's Avatar
Default ECU Schematic
Does anyone have a complete schematic for the ECU?
Trying to nail down an electronic issue.
Thanks
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 12-23-2019   #2
Subfixer
Subfixer's Avatar
Default Re: ECU Schematic
Since there hasn't been any response, I'll guess no one has an ECU schematic.
Old 12-23-2019   #3
geezer
What is the " electronic issue" you are chasing?
geezer is offline   Reply With Quote
Old 12-24-2019   #4
Subfixer
Subfixer's Avatar
Intermittent code 42. I've replaced everything in that circuit, but the problem continues.
Old 12-24-2019   #5
Did you see this?
http://zr1.net/forum/showthread.php?t=17291
Might help
Old 12-24-2019   #6
Karl
Karl's Avatar
Did you recently pull the plenum?
http://www.zr1.net/forum/showthread.php?t=31249
I thought the ecm wiring is located in the shop manual.
Old 12-24-2019   #7
Wiring yes, I assumed he wanted an internal schematic for the ECM..
Old 12-25-2019   #8
Ccmano
Did you see this?
Might help
I posted that thread. With the code 42 being intermittent there is a possibility that a DIS pin may not be totally bent but rather misaligned enough to miss going through the center of its respective connector and pass between the connector and the connector housing. The other possibility is a pin connector that has been enlarged, so that the pin goes through it but the electrical connection between them is not good. The OP may want to check the main DIS connector for these issues. I seem to recall someone on the forum had the latter condition with a similar intermittent problem. The code that is generated will depend on which pin is affected.
H
Old 12-25-2019   #9
Subfixer
Subfixer's Avatar
Plenum pull will be the next step.
This problem first showed up sometime after my last plenum pull just before Carlisle.
Code 42 started showing up a month after the Carlisle trip.
Sometimes to won't set for a few days. Other times it sets several times a day. No real pattern.
All cables checked, knock sensor and O2's replaced.
Code shows with both stock chip and Mark's chip.
Last things left are DIS module (I have a spare) or ECU (no spare - reason for needing internal schematic).
