![]() Join Date: Jul 2019
The cruise in my 1990 ZR1 does not engage or work. Any suggestions. Im still very new to corvettes.
Sent from my SM-G975U using ZR-1 Net Registry mobile app
George Zugg 1990 DRM 500 ZR1 build#952 [SIGPIC][/SIGPIC] ![]() |
![]() Join Date: Jun 2005
Welcome to the ZR1 Net, "Zugg ZR-1".
After reading the above and your other post about no low beams, it sounds like you are going to do some DIY service work on some electrical items. Step 1) Buy a Factory Service Manual. They are available from Zip Products.
![]() Join Date: Oct 2017
Hib has the #1 step exactly correct. Some would differ, but I think a complete FSM is mandatory.
That step behind us, as you are having headlight dimming and cruise control activation issues, the common thread is the control on the steering column. Possible wiring connections or broken wires? ![]()
Kenny 1990 #442 ![]() |
![]() Join Date: Jul 2015
ZuggZR-1 - Welcome aboard as a new ZR-1 owner! I had the same issue in my 1991 ZR-1 this summer. Look under the round module on firewall on the driver's side. Underneath there is a control cable leading to the Cruise Control Module that fits into two slots. Make sure the cable is engaged in those slots, it can slip out and cause the Cruise Control to not engage when you press the stalk button. Will send pictures if you need them.
![]() Join Date: Jun 2019
Also the third brake light on most vehicles of the era is linked to the cruise control. If the bulb burns out the cruise will not work. It was a way of warning the driver that the bulb has burned out.
Check the brake light switch , some have vacuum lines ,that have an o-ring that goes bad . Its good to have a mighty-vac tool to check for leaks in vacuum lines .
Make sure the brake light switch is centered on the brake pedal arm and not askew. If it is not centered the cruise will not engage.
![]() Join Date: Jul 2012
Cruise control stopped working on my'93 many years ago. Turned out the vacuum hose that runs through the firewall and under the dash had been rubbed thru by the clutch pedal. The hose had been improperly routed from the factory.
Sent from my SM-G975U1 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167 368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP. |
#9 |
#10 | |
Thanks George Sent from my SM-G975U using ZR-1 Net Registry mobile app
