12-02-2019 | #1 |
1990 ZR1 Head Lights stuck on High Beams
My 90 ZR1 has head lights that work fine but will not switch to low beams. Any suggestions?
Sent from my SM-G975U using ZR-1 Net Registry mobile app
George Zugg 1990 DRM 500 ZR1 build#952 |
12-02-2019 | #2 | |
Re: 1990 ZR1 Head Lights stuck on High Beams
12-05-2019 | #3 |
Try changing from hi to low with the tilt in different positions , it could be the rod that goes to the switch or the switch under the dash on the column
12-05-2019 | #4 |
12-09-2019 | #5 | |
12-09-2019 | #6 |
I zip tied some cables to the steering column. The result was the same problem you are having. I could select high beam, but not back to low.
- '90 ZR-1 |
