Old 10-31-2019   #1
Default Compression check-up
Was changing plugs last changed around 2008... Plugs NGK BKR7EIX gap .050
At that time I also did a compression check stock catback Marc' prom
engine temp 195
2- 230 4- 225 6- 228 8- 225
1- 230 3- 226 5- 230 7- 228
Fast forward today 2019 Marc's 510hp package done 12/2013
Cold engine Going back tp AC 41-602
2- 238 4- 238 6- 240 8- 240
1- 232 3- 233 4- 232 7- 234
BLM Left bank 136
BLM right bank 132
Int-L 127
Int R 128
Map Volts 1.33-139
TP Sensor 0.53v
02 R & L 83-890
I have a vid from the scanner readings but can't post here
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-31-2019   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Compression check-up
Nice numbers,
How many miles in the meantime?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 10-31-2019   #3
45k in 2008, 53k in 2013 when I took it to Marc, Just turned 62K.
The increase in compression was due to the MLS head gaskets that Marc used.
"The compressed thickness of the MLS gasket is .050" verses .065" for the OE gasket. For a 350 ci engine, the MLS gasket will add .4 to the compression ratio. If the original compression was 11.0:1 it will increase to 11.4:1"
Steve
1990 Red/Red #1473
