Old 10-17-2019   #1
Vette73
Default Front shock question..
Going to change the front shocks on my 91...Don't want to damage the actuator ...How does it come off ? Straight pull ? Twist and pull ?..
Vette73 is offline   Reply With Quote
Old 10-17-2019   #2
Default Re: Front shock question..
To remove the actuator (motor on top) Remove the clip at the base and just lift off.
http://www.captainzcnc.com/id2.html
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-17-2019   #3
Vette73
Ok thanks....I should ask, my car is a 91 and the front shocks I got were off a 93 ZR1.....Is there any difference ? Will they match up ?
Old 10-17-2019   #4
Not sure, I know they'll fit and that the 93 had a different program.
Steve
1990 Red/Red #1473
Old 10-17-2019   #5
billschroeder5842
billschroeder5842's Avatar
I'm not sure it will fit. The 89-92 had a similar spec brass "nut" on the top and the 93-95 had a different size. I'm not sure if you have to swap actuators (and will they work with "the box" or if you can swap out "nuts?"
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 10-17-2019   #6
bddeuce
My understanding is there are (2) series of shocks 89-91 and 92-95. The difference is in the amount of rotation the adjustment gear on the top of the shock has. 92-95 have less rotation. You should be able to confirm the amount of rotation between the (2) types of shocks. Bilstein recently made a production run and many retailers still have them in stock.
bddeuce is offline   Reply With Quote
Old 10-17-2019   #7
Vette73
I believe Rock auto has them ...Selective ride bilstein ( 3 day delay ) 193.00 each....
Will put these in the parts for sale section..
Old 10-18-2019   #8
EvanZR1
EvanZR1's Avatar
bddeuce is correct. The 93 shocks will fit on a 91, but they won't function correctly as the controller won't move the actuator to the proper positions. You need to run all four shocks from the same year group (89-81 or 92-95). The actuators work across all years, but along with the shocks, you'll need to make sure you have the correct controller (again, running 92+ shocks with a 91 controller won't give you the proper valve position).
Evan
2024 Z06
SOLD - 1991 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
EvanZR1 is offline   Reply With Quote
Old 10-24-2019   #9
rkreigh
no Bueno. You can't mix these.
you either need the correct shocks, or buy 92-95 for the rears and update the FX3 controller.
I did find out you can use the same wiring. I ran 90 shocks in the LSV with a 90 controller and the fx3 worked just fine
the shocks need to match controller box
95 390 LPE ZR1 (505 rwhp)
Old 10-25-2019   #10
dfrancis
Have you posted these for sale very interested for my 93?
Dave
1993 Ruby Red 40th Anniversary ZR-1 #127
2011 Black ZR1 #132
[SIGPIC][/SIGPIC]
dfrancis is offline   Reply With Quote
