I am getting a Service ABS light on the DIC. Is there an easy way to download codes for the ABS system?
Thanks David |
![]() Join Date: Oct 2017
There is a lot of info in the "stickies" by Dynomite.
Also, here's an article by Hib. https://www.corvetteactioncenter.com...abs/index.html ![]()
Kenny 1990 #442 ![]() |
![]() Join Date: Apr 2004
I just went thru this on a 93 that article gave me a great understanding of how it works. I was able to get the codes thur the on board diagnostic.
But I also have a scanner that reads ABS/ASR had DTC 63,64,72. Went to the FSM and found all the plugs to the modules. I unplugged all and plugged even the relays at the pump. removed and cleaned the ABS fuse. than cleared the codes and all was good. I think 72 (Serial data Link) was the main culprit.
You'll need a TechOne to read and reset the ABS Code.
I had an ABS Relay fail causing ABS code 63. Turns out, the relay is practically unobtanium. The few I found were stupid expensive, but the schematics showed it to be just a standard 12v relay with an unusual plug at the base. My fix was simple and cheap and extremely straightforward. 6 years later, still no ABS codes. http://www.zr1.net/forum/showpost.ph...0&postcount=17 http://www.zr1.net/forum/showpost.ph...1&postcount=18 Crabs |
You can read the codes using the DLC Hib tells how on page 2 paragraph starting with, No Tester Read the Flashes. This is for 90-91.
Gordon K. also sells a cheater plug to do this. A good scanner with ABS will also read and clear the codes but only a Tech1 will do the function tests.
THANKS
I will read the codes and see where that leads. |
