Old 09-29-2019   #1
conesare2seconds
Default Door belt line moldings
Hi there. Are the door belt line moldings longer on the ZR-1, or same part # as the base car?
Old 09-29-2019   #2
dredgeguy
dredgeguy's Avatar
Default Re: Door belt line moldings
I know the short piece is longer on the Z
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-29-2019   #3
conesare2seconds
You’re right. I should spec I’m asking about the molding on the door.
Old 09-29-2019   #4
TX '90 ZR1
TX '90 ZR1's Avatar
I have been told they are the same. Might check with Mark @ Mirrock. He will know for sure.
Kenny
1990 #442
Old 09-29-2019   #5
Old 09-29-2019   #6
They are the same part on a 91-95,I know this for fact. I wanted to repaint the door trim on my 91,I thought that other than the threaded stud at each end the center of the trim had snaps,wrong. On the early 91s,at least up to VIN 634,the trim has threaded studs the length of the trim,I destroyed one piece getting it off. I’m looking for a driver door piece with all threaded studs if anybody happens to have one.
Old 09-30-2019   #7
conesare2seconds
Appreciate the responses.
Old 10-06-2019   #8
I forgot to add,THE ENTIRE DOOR HAD TO COME APART TO GET TO ALL THE NUTS! That was one of the situations that if you ever got the chance to meet the engineer that designed that part,you'd slap em.
Old 10-06-2019   #9
HAWAIIZR-1's Avatar
The door molding is same for 90. I have them NOS and checked the part numbers. Only the dog leg (or whatever that piece is behind the door is) and rear bumpers have different molding than a standard C4.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
