Old 09-28-2019   #1
FormulaReed
Default TPS adjustment
I don’t have the harness breakout tool but I need to adjust the new throttle position sensor on my car. I really don’t want to hack into my wiring loom.
Any one have a tip for doing it without the harness breakout tool? Went to order one from mid America but it’s out of stock.
My car is a 1991.
Thanks,
Reed
FormulaReed is offline   Reply With Quote
Old 09-28-2019   #2
Default Re: TPS adjustment
A decent setting can be obtained by setting it midway between the limits, which places the TP Sensor horizontally level.
Old 09-28-2019   #3
It’s possible to rig a set up to get the setting.
Old 09-28-2019   #4
Jagdpanzer
Jagdpanzer's Avatar
Until I got my Tech 1 scan tool I used a straight pen an a volt meter
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-29-2019   #5
You guys should just spring for an inexpensive Android tablet and $35 for ALDLdroid along with an ALDL connector. U’ll use it over and over and over again.
Old 09-29-2019   #6
FormulaReed
Sorry to sound like an idiot, but what do you mean by “straight pen”?
I’ve got the tps in now by just centering the bolts. All ready drives better than before, but I’d like to get it adjusted properly.
Old 09-29-2019   #7
BigJohn
BigJohn's Avatar
Straight pin ?
Old 09-29-2019   #8
Using a straight pin you can puncture the wire insulation to attain a voltage reading without hacking the harness. (Purchasing the tablet etc.., as Dom suggested is the best way to monitoring a host of parameters. Money well spent!)
Old 09-29-2019   #9
Ccmano
The is setup works nicely for datalogging and for individual settings like this, I use it too. As Dom stated you’ll need a cheap android tablet, the ALDLDroid software and an ALDL cable (direct or Bluetooth). The website for ALDLDroid explains and has links to obtain all the hardware. Www.aldldroid.com.
Total investment should be under $100.
H
Old 12-22-2019   #10
FormulaReed
I got a aldl android set up and I was going to use it to set the TPS voltage.
I've never used scanner before so this is going to be a stupid question but are the volts the top value on my data log? If not, how do I get the app to show tps voltage?Screenshot_2019-12-22-16-14-42.jpeg
Sent from my SM-T280 using ZR-1 Net Registry mobile app
