Old 09-09-2019   #1
Vette73
Default Tire question ( weight )
Anyone know the lightest weight tires for our cars are? Also maybe the heaviest ..?
Vette73 is offline   Reply With Quote
Old 09-09-2019   #2
lfalzarano
The Goodyear Eagle[emoji768] F1 GS-D3[emoji769] fronts are 27 pounds each and the tears are 30 pounds each.
The Michelin’s Pilot Sport PS2 fronts are 24 pounds each for the same 275/40ZR 17’s while the rears are 34 pounds each, but are 335/35ZR 17’s. The standard rear Goodyear F1 GS-D3’s are 315/35 17’s, but have a narrower tread at 30 pounds each.
Is the above examples, the Goodyear’s are 2 pounds lighter per full set than the Michelin’s.
From my driving experience with both brands, the Michelin’s are superior in ride and dry handling. Skip dinner and the car will weigh the same with the Michelin’s. [emoji23]
JMHO
Old 09-09-2019   #3
Vette73
Default Re: Tire question ( weight )
JMHO
Old 09-09-2019   #4
BigJohn
BigJohn's Avatar
Cut tires work great and are Lighter than stock.
Old 09-10-2019   #5
RussMcB
What's the reason for asking? For racing? If yes, I'd think things like compound and construction would probably be more important.
The lowest unsprung weight is best, for sure, but by the time you consider the wheel, brake parts, hubs, and half the axle, shock and suspension arms, the tire weight isn't likely noticeable.
But, I suppose it does takes more power to spin up a heaver tire ...
