Old 09-08-2019   #1
BigDave
Default FS: 93 ZR1 Engine and Suspension Parts
I have a 93 Anniversary Ruby Red ZR1 that had 6800 miles when damaged which I decided to part out. The car has been garaged for the last 15-20 years. This post is for Engine and Suspension parts. If you need an item not listed please ask. All prices are plus shipping.
Coolant Outlet covers (Right and Left, Pair) - Sold
Spark Plug wire Set (Corvette Lt5) - Sold
Intake Plenum - Sold
Throttle Body - Sold
Intake Air Horn - $65
Fuel Injector Housing (Pair) - Sold
Fuel Rails (Pair) - $225
Fuel Rail Crossover Tubes - $115
Fuel regulator - Sold
Coil Tray with 4 Coils - $110
Ignition Control Module - Sold
Alternator - $100
Clutch Master Cylinder - $75
Clutch Slave Cylinder - $75
Clutch Master to Slave line - $40
Secondary linkage, diagrams, shielding and hardware - $175
Exhaust shielding (5 pieces) and bolts - $125
PCV valves and crossover - $75
Engine shielding (7 pieces) - $135
Positive battery cable - $40
Negative battery cable - $35
Fork and pivot - Sold
Bellhousing and Dust Shield - $225
Starter - Sold
Power Steering Pump - Sold
Power Steering Pump Bracket - $85
Power Steering reservoir and hose - $40
Front Leaf Spring - $85
Rear Leaf Spring - $85
Front Leaf Spring Mounting Hardware - $45
Rear Leaf Spring Mounting Hardware - $45
Front Sway Bar and Mounting Hardware - $100
Rear Sway Bar and Mounting Hardware - $100
Front Selective Ride Shocks (pair) - Sold
Front Electrical Actuator (pair) - Sold
Rear Selective Ride Shocks (pair) - Sold
Rear Electrical Actuator (pair) - Sold
Front Shock Mounting bolts - $15
Rear Shock Mounting Hardware - $35
Intake Air Horn Bolts - $20
Water Pump Bolts - $35
Fuel Injector Housing bolts - $40
Exhaust Manifold bolts with spacers - $40
Throttle Body shield and bolts - $40
Coil Tray Bolts - $15
Ignition Control Module Bolts - $20
Alternator Bracket and bolts - $40
Flywheel Bolts - $30
Coolant outlet cover bolts - $25
Transmission to bellhousing bolts - $20
Bellhousing to Engine bolts (Includes dust shield bolts) - $30
Water Pump to A/C bracket and bolts - $30
Intake Plenum Bolts - $30
BigDave is offline   Reply With Quote
Old 09-08-2019   #2
Default Re: FS: 93 ZR1 Engine and Suspension Parts
Message sent
Old 09-08-2019   #3
I’ll buy the fuel regulator if it will work on a 91.
Old 09-20-2019   #4
93z
wheels?
93z is offline   Reply With Quote
Old 09-21-2019   #5
BigDave
The wheels are sold.
Old 09-21-2019   #6
Vette73
PM sent
Vette73 is offline   Reply With Quote
Old 10-10-2019   #7
Subfixer
Subfixer's Avatar
PM sent
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 10-30-2019   #8
Subfixer
Subfixer's Avatar
What happened to the rest of the engine?
Old 10-30-2019   #9
BigDave
The short block and heads are sold.
Old 10-30-2019   #10
billschroeder5842
billschroeder5842's Avatar
Pm sent!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
