![]() Join Date: Jan 2018
recent acquirer of a 91 zr1. love it. taking it to the track for some hpde.
ive read about the bypass, studied dynomites posts and read about other experiences. the root issue as i understand it is, and fill me in if im wrong, is that the orifice sizes of the radiators are too small and therefore the pump cavitates and excess pressure is built up and the pressure relieve operation in the crossover was a way to get around this. so my question is, is there a triple or double core that has been designed to accomodate higher gpm flow rate at wot? this would avoid the cavitation. avoid the pressure. avoid the bypass and recirculating of some uncooled fluid. if i had to install a swedge to expand the size of the coolant hose i would do it. the bottom would be tight but id find a way. thanks. |
#2 | |
Now having said that, I would expect the various aluminum radiators to not have this inherent weakness not having the same end seals as the stock radiator. Further, the flow characteristics would be different for each radiator (head loss, coolant paths, and heat transfer). As Per Marc Haibeck graph provided to the ZR-1 Net email list by Graham Behan about ten years ago, the Coolant Pump flow rate through the engine (not the radiator or thermostat) is: 15 gpm at 800 rpm 18 gpm at 1,000 rpm, 44 gpm at 2,000 rpm, 65 gpm at 3,000 rpm, 90 gpm at 4.000 rpm, 120 gpm at 5,000 rpm at which time cavitation is starting. We do not know water pump flow after cavitation starts and we do not know head loss of coolant flow through various radiators. We do not know current pump flow through stock radiator as the test above was pump flow through engine only. I have not seen the design pressure characteristics of Aluminum Radiators listed and would assume which pressure is greatest at the top and reduced by head loss as coolant is forced through radiator. This whole discussion is a bit complicated by a water pump that does not function well on either end of the rpm range of the engine and a radiator with an inherent weakness because GM did not want a unique radiator for the circumstances 😜 Instead GM settled on a most unique thermostat housing and thermostat to solve the high coolant temperature issues (Warm Climates) associated with high engine rpm and the radiator pressure using a conventional water pump impeller which works for most of us. That is except for HOT desert climates and traffic (we then go to Aluminum multi core radiators keeping rpms above 2,000 rpm in traffic) ![]() Some guys have even modified fan function for higher air flow rate which definitely will help coolant high temperature issues in traffic ![]() If we determine that our multi core aluminum radiators will take the pressure we still have the cavitating water pump as a secondary issue.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-03-2019 at 02:21 AM. |
Thank you for the reply Dynomite!
Ive noted your path for an increased radiator cooling has been the ron davis, lately. My circumstance is that i want to build an LT5 road track car for lapping and track days. If possible, id like to “”let the beast out” in those higher rpms and when i learned about the whole waterpump issue castrating an otherwise incredible piece of equipment it bothered me. i havnt found a well documented solution, which, now that you have refreshed me on cavitation, it sounds like an electric waterpump which controls the impeller rpm in a nonlinear relationship to engine rpm is the only solution. combined with the ron davis or dewitts. do we have members of this forum currently running electric water pumps and have they demonstrated it as being the fix? |
#4 | |
![]() http://zr1.net/forum/showthread.php?p=227285 More Electric Water Pump Discussions follow: http://zr1.net/forum/showthread.php?t=25524 http://zr1.net/forum/showthread.php?t=25219 http://zr1.net/forum/showthread.php?t=16562 In this post grahambehan verifies that Cavitation reduces water pump flow at high water pump rpms. http://zr1.net/forum/showthread.php?p=227422
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-03-2019 at 12:20 AM. |
You can also run Pete's underdrive and lightweight water pump pulley and increase the useable rpm of the water pump before cavitation happens.
I have one on my '93 and had one on my '92 and no issues. Granted I do not do road racing or such, I do drive my Z agressively on a regular basis. Last edited by Karl; 09-04-2019 at 12:16 AM. |
#7 | |
Here is my plan:
1. drill 3 x 1/8th holes in the stock 180 tstat, with factory radiator. see what happens at the track. I took the time to pull the oil cooler and radiator and clean them all up, they were full of crap, so i'd like to have my own baseline experience of the stock system with the 3 1/8th hoes. The 1/8th holes are to help increase pressure transmitivity through the thermostat restriction and thereby an attempt at eeking another few hundred rpm before the bypass reaches its relief pressure. I will log this. 2. install a ron davis or dewitts 2 row x 1' wide radiator. If any of you have a used one that has been pressure tested and would like to sell it, let me know i will buy it. 3. try the electric pump. my idea for the "warning light" if the pump is not turning, is to install 2 x large RED LED bulb and place them into the ventilation louvers, so they are out of sight and totally un-noticable, UNLESS the electric pump has failed then they will light up and the car can be immediately pulled over or off the track in my case. any ideas on the right type of sensor to detect normal operation of the e waterpump? i was thinking as long as the circut is completed then the light will be off. if it fails, then it lights up. however, it occured to me that similar to the secondary vacuum pump, it could seize, but still take power. so then i was thinking a pressure sensor, as long as the waterpump maintains a certain pressure in the system, then the circut to the light isn't completed. but if it drops below the rating of the sensor, it lights the lights. but then i was thinking if you don't catch it in time, you could easily boil your engine, and the pressure from the excess heat would keep the warning lights off. thoughts please. |
#9 |
![]() Join Date: Dec 2003
Another factor in heat transfer that has not been discussed, is retention time. When velocity increases, the contact time for thermal transfer is reduced. Increasing the flow rate through the engine with a higher capacity electric pump will result in higher pump discharge pressure, due to the fixed restriction area of the engine. So there will be a point of diminishing returns that we really don't have data on.
The cavitation, described by Dynomite is an inherent characteristic of centrifugal pumps due to insufficient suction head pressure. This is frequently solved by multistage centrifugal pumps, i.e. more than 1 centrifugal pump in series. The differential pressure across the radiator may be rectified with a higher flow capacity radiator. I contacted Ron Davis years ago about the radiator flow capacity, gpm at max rated working pressure of the radiator. They had not performed that test at that time. I think that needs to be established as it may solve a portion or even all of the cavitation issues with the stock water pump, depending on how the flow rate through the engine is affected by the higher flow rate. From my conversation with Ron Davis, their primary design focuses on racing. For NASCAR, that means sustained high speed which pushes a lot of air through the radiator. Road track racing isn't going to be quite the same. Maybe someone (Dynomite??) will take the chance, by blocking off the bypass and running some high rpm passes at different speeds to see how much the cooling system will take. And then there's always the thermostat to consider. Will it ultimately be the restriction that is to blame? Will it even handle 120gpm or even 90gpm? How about the engine's flow characteristics? What is the maximum flow rate that can be achieved within the pressure limitation of the system?
#10 | |
I've read them all and I now have a "pathway" to a solution. I will gather data along the way. It does appear that I could get to a sustained 5800~ish rpm with dewitts or ron davis and a few holes drilled in the tbody flange and not overheat. truth is i am looking to wind this baby up to her potential as a track superstar and therefore looking for a cooling solution all the way up to the late 6000's and early 7000's. we shall see and I will surely report findings back here. |
