Old 04-03-2007   #1
zr-1assassin
zr-1assassin's Avatar
Default fuel filter?? how many and what kind??
hi all, i think its time to change the fuel filter(s). can someone tell me if there is just the one and give me a part#? also any tips on doing the job....as i will be doing it myself as so many of us do thanks!
zr-1assassin is offline   Reply With Quote
Old 04-03-2007   #2
Peaven
Peaven's Avatar
Default Re: fuel filter?? how many and what kind??
From what little I've read, the stock GM replacements are fine and available.
Peaven is offline   Reply With Quote
Old 04-03-2007   #3
1990 quasar blue
GM 25055052
Delco GF481
Fram G3727
HASTINGS GF111
PUROLATOR F33144
WIX 33481
Relieve the pressure at the Schrader valve on the fuel rail and loosen the gas cap.
Old 04-03-2007   #4
zr-1assassin
thanks guys, i went to chevy and they gave me #GF652F ACDelco. can someone confirm this is the correct filter? GM#89058397. thanks!
Old 04-04-2007   #5
ffvetteman
I think I got a Purlator or something but have not replaced it yet. I got it thinking it may be why my car was running bad, but I checked the pressure at the fuel rail and was all good, so I never replaced it.
I may do it just to see if there will be any difference in the pressure. I was toward the lower end of the factory specs, but still well within good range.
ffvetteman is offline   Reply With Quote
Old 04-04-2007   #6
I'm no expert but neither of those #'s are what I get at the chevy dealer. I order by application and it's always been GF481. Mind the small o-rings on the hard lines going into the filter. Make sure ya don't loose them or that they are nicked or in bad shape. I change my F/F every year....it's cheaper that the pumps.
