Old 08-22-2019   #1
Roadster
Roadster's Avatar
Default Coolant pipe hose question....
Purchased a complete radiator hose system for the ZR-1 years ago....but finding out that the coolant pipe hoses are shorter than what I have now....
Doing some research has anyone used the Dayco 70704 hose with any success?? Compared that at the auto store to the replacement that I have and looks to be smaller in the ID and OD....
also checking out Gates 20786 hose to also cut to size for the coolant pipes....
Also anyone have the correct ID and OD of the coolant pipe hoses???
Thanks for any info....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-22-2019   #2
Roadster
Roadster's Avatar
Default Re: Coolant pipe hose question....
Replacement coolant pipe hose that I have...shorter in length than the originals....20190822_161725.jpg
Sent from my SM-G965U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-22-2019   #3
TX '90 ZR1
TX '90 ZR1's Avatar
Marc Haibeck has the coolant hoses. Jerry's Gaskets may have them as well.
Kenny
1990 #442
Old 08-22-2019   #4
Roadster
Roadster's Avatar
Thanks....but don't need the whole set....already have them...looking for something close that I can cut to size...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-22-2019   #5
TX '90 ZR1
TX '90 ZR1's Avatar
If you don't locate something I'm pretty sure Marc has the hoses individually. Not sure about Jerry.
Good Luck
Kenny
1990 #442
Old 08-22-2019   #6
Roadster
Roadster's Avatar
Thanks Kenny.....will check that out!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
