Old 08-03-2019   #1
RussMcB
Default Defroster blower won't turn off - Cheap Solution
Apologies if this info is already here. I didn't find it with the search words I used.
Recently I turned off my car and the defroster blower motor was running hard, and didn't turn off, even after removing the key and leaving the car. Luckily I had a battery disconnect switch, otherwise it would have been a dead battery for sure.
Once home I Googled and found this perfect video:
https://www.youtube.com/watch?v=WT5u2LwhXhI
Not only does it identify the problem (control module), but also that a $30 '93 Jeep Cherokee part is identical and much cheaper than the Corvette PN.
I still shake my head when I think about trying to solve problems before the internet filled up with all this valuable information.
Old 08-04-2019   #2
tiegsd
tiegsd's Avatar
Default Re: Defroster blower won't turn off - Cheap Solution
Will put that one on my mental shelf just in case. Thanks!
1990 Black/Black ZR-1 #1155
1993 White/Red coupe (Regrettably sold)
tiegsd is offline   Reply With Quote
Tags
defroster, heater, motor, stuck
