Old 07-28-2019   #1
Jetjock
Jetjock's Avatar
Default FX3 Issues
I got a code 22 on my 92 Z. Right rear timeout. I talked to Gordon and he suggested that the nut on top of the shock maybe loose. It wasn’t. According to the manual, I checked that the selector on top of the shock was loose and free and it was. I then reconnected the actuator control back up to the car after checking for broken teeth. I had someone turn the ignition on and there was nothing. I did this several times with the same result. Then I reached up to the connector and turned it around and then actuator started going back and forth like crazy and then stopped. It did this a couple of times when I had the key on and off. I’m of the opinion that the connector somehow didn’t make a good connection and threw the code for whatever reason. FYI, the shock had no leakage at all.
Thoughts?
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
Jetjock is offline   Reply With Quote
Old 07-28-2019   #2
Ccmano
Default Re: FX3 Issues
Sounds like you got it. I would have clean the connector real good and added some dielectric grease to seal it.
H
Old 07-28-2019   #3
Jetjock
Jetjock's Avatar
I think so. I’ll find out tomorrow.
Roy L. Carman
NCM Lifetime #1468
Old 07-29-2019   #4
Jetjock
Jetjock's Avatar
A big question for you guys. I went through and checked everything and it looks good. However, do I have go drive it to get the code to disappear? The code 22 is still coming up. I’m going to check the voltage and see if the feedback circuit works. Just curious if you have drive it after checking it.
Roy L. Carman
NCM Lifetime #1468
Old 07-29-2019   #5
EvanZR1
EvanZR1's Avatar
If it's working, it should clear. I recently had an issue with one of my fronts and the light went out on the next start after fixing the issue.
EvanZR1 is offline   Reply With Quote
Old 07-29-2019   #6
Jetjock
Jetjock's Avatar
What was the issue, Evan?
Roy L. Carman
NCM Lifetime #1468
Old 07-30-2019   #7
EvanZR1
EvanZR1's Avatar
Self induced issue. Had pulled both front controllers to inspect, and found the right front gear needed replacing. Got that done, then reinstalled both but still had the light. Apparently I hadn't reseated the right front properly, as I took it off and reseated it and the light immediately cleared.
Old 07-30-2019   #8
dredgeguy
dredgeguy's Avatar
Just did the same with a Service Ride Control 21 code (front left time out). I took the actuator off to check the metal gear on top, all looked good. Unplugged the connector and all looked good so reconnected. Turned the key on (no need to start up), light went out.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
