07-22-2019 | #1 |
Shelby wheels brake upgrade
Need definitive answers from folks on what the options are for front brake upgrades with Shelby wheels. The two options I'm aware of are:
Evan
2024 Z06 SOLD - 1991 Admiral Blue ZR-1 SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP SOLD - Steel Blue 91 391cid ZR-1 #391 SOLD - Black 91 ZR-1 |
07-22-2019 | #2 | |
Re: Shelby wheels brake upgrade
I assume you mean you have the Calipers and their associated brackets but are not using C4 to C5 adapters (I have seen this before) That said, you will need to move the Centers out on the fronts to clear, you will also need a 3/16 minimum spacer.. I had C5 brakes with Shelbys Wilwood Superlites (are these the Narrow Superlites)? I know the 12.88" narrow kit will work with centers in either spot. I have the NSL Wilwoods on my car (12.88") and originally had the centers on the inside, but moved to the outside to get the new tires I have to tuck better under the fender.. I also know the Standard SuperLites will need a spacer and be on the outside to keep the tire in more With your C5 rears, I am guessing they should fit but I currently run the OEM C4 rears. If I ever buy that C5 conversion set-up for a drum parking brake, I will run C5 calipers in the rear hope that helps and makes sense
07-22-2019 | #3 |
Correct, I have the C5 front setup sitting on a shelf, but have not ordered the custom mounting brackets for bolting them to a C4. I wasn't planning on doing anything with the rears at present.
Here are the two options listed by Wilwood on their site: https://www.wilwood.com/BrakeKits/Br...axle=Front+Kit Both say "Narrrow Superlite". To be clear, I'm just looking at upgrading the fronts at present.
Evan
07-22-2019 | #4 |
The 12.88 will work, that is what I have currently.. Centers can be on the inside out outside of the barrel
07-22-2019 | #5 |
I do not think the C5 brakes are worth the trouble.
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
07-22-2019 | #6 |
agreed.. If anything do the Wilwoods or leave it alone
07-22-2019 | #7 |
Thanks, that's the kind of feedback I was looking for. I got them for a steal, so I should be able to sell them easily for at least what I have in them.
Evan
07-22-2019 | #8 |
Sell? What time up going to replace them with?
07-22-2019 | #9 |
Anyway, I'll sell of the C5 setup I never installed, and just buy the Wilwood 12.88" setup for the front.
Evan
07-22-2019 | #10 |
Sorry,
What are you going to replace the Shelby’s with? Oh you mean sell the brakes
