Just starting a plenum pull to do injectors and starter, and I notice I have a oil leak at what I believe to be the cam position sensor but I’m having a hard time finding a replacement any recommendation where to find one. Thanks
Just replace the Oring ?
I have not removed it yet but I will check that, thanks
![]() Join Date: Aug 2006
In case you need it.
https://www.jerrysgaskets.com/seal-c...r-90-95-7-5c5/ |
One thing to be aware of, where the sensor is positioned on the down side of the cylinder head it constantly sits in a small pool oil whether the engine is running or not. Therefore, if the Oring stops sealing or the sensor develops a crack you will definitely see an oil leak.
#6 | |
