Old 06-23-2019   #1
Tripler
Tripler's Avatar
Default Ruff Idle ,Huge Loss of Power
Hey guys/gals . Was driving the 1995 Z today and all of a sudden the engine lost power and developed a ruff idle . It also seemed to be running on very few cylinders . It was working fine on the highway but once I got close to home , it began the loss of power and ruff idle in city traffic . Would a gas cap not being tight enough create this issue ? Also could it be the fuel filter ? It has a half filled gas tank and car always gets Shell 91 octane Ethanol free gas .
Thanks
Mike
Tripler is offline   Reply With Quote
Old 06-23-2019   #2
secondchance
Default Re: Ruff Idle ,Huge Loss of Power
Thanks
Mike
Hi Mike!
Did it backfire? First, I would check MAP sensor hose between the MAP sensor and the back of the plenum.
Loose gas cap wouldn’t cause symptoms you are seeing.
Old 06-23-2019   #3
dredgeguy
dredgeguy's Avatar
Hi Mike, sounds like a problem I had in the past. One of the fuel pump hoses was loose and just hanging. The fix was new hose clamps. Good luck and keep us posted.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 06-23-2019   #4
Tripler
Tripler's Avatar
Hey . Thanks for quick responses . I will give those tips a look tomorrow . Thanks 😊
Mike
Old 06-23-2019   #5
Tripler
Tripler's Avatar
Hi Mike!
Actually it did backfire once .
Thanks for the tip .
Old 06-24-2019   #6
Tripler
Tripler's Avatar
Hey Charlie ! Hows things . Finally got warm weather up here so busy tuning my motor bikes ( I have 3 , 2 plated and one for track only ) and of course getting the Z and the 6 out once a week at least . I will be looking at the car this morning and will let you know what I find .
Mike
Old 06-24-2019   #7
Tripler
Tripler's Avatar
Morning. A small hard black hose was not attached to a softer rubber 90 elbow. Is that the MAP Sensor ? . I reconnected it but still runs a bit ruff . Do I need to take it for a drive to reset everything ? Should I be looking for anything else ?
Mike
Old 06-24-2019   #8
secondchance
Mike
Was this hose between the back of the plenum to underside of MAP sensor? MAP sensor is under an aluminum trim behind the plenum. Once reconnected, all should return to normal. If not, I suspect something else blew off under the plenum on top of MAP sensor hose when it backfired.
Old 06-24-2019   #9
dredgeguy
dredgeguy's Avatar
Hi Mike, all well here. Sitting in Dhaka, Bangladesh now until the end of the month. Hope you track down the problem. When my issue started, engine felt like it was going to stall and that is when we found one of the fuel pumps disconnected. Keep us posted.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 06-24-2019   #10
Mystic ZR-1
Mystic ZR-1's Avatar
Dhaka Bangladesh!
Damn!!!
Charlie, I know I’ve said it before, but,
you get to go to the places us mere mortals can
only dream about!!!
