Old 06-23-2019   #1
cadillac531
cadillac531's Avatar
Default Tips on winching a Z up a trailer...
Anyone have any tips on this?
I was going to go to the track this morning. I had the trailer all ready to go and have a 12,000 lb winch on the front of the trailer. I was going to meet the local club at the track, but was ultimately loading and unloading alone. I've loaded this car on trailers before, but had spotters and drove it up backwards.
This time I needed to be able to load it myself using the winch, which meant it has to go forward on the trailer. No go. I had the trailer tongue jacked up to lower the back end of the trailer and had 2x6 wood extensions to get the nose of the car up. The winch cable, though, was still pushing up on the chin spoiler and had I kept pulling, it would have broken.
Does anyone routinely load their car onto a trailer with a winch? Any tips here? Would a tow strap up front help me? If so, how and where would it hook to?
Thanks in advance.
Signed,
Moderately irritated for wasting 2 hours of time this morning.
Constantine
Registry Founding Member #0235
1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete.
1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car.
https://www.youtube.com/watch?v=z8y4cwcvK0s
1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car.
1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything.
cadillac531 is offline   Reply With Quote
Old 06-23-2019   #2
cadillac531
Default Re: Tips on winching a Z up a trailer...
OK, I think I figured it out. Just went back outside and looked underneath. There are two seams on either side of the radiator beneath the urethane bumper and above the spoiler. I can feed a tow strap through there and hook to the cradle. If I do this on both sides, it will give me a triangular strap that can be hooked to the winch.
I'll get another strap next time I'm out and try this. I think it'll work.
Thanks.
Signed,
A little less irritated, since I think I figured it out.
Constantine
Old 06-23-2019   #3
aafc
aafc's Avatar
I load my Z onto a trailer by myself, by placing a 4x4 under the trailer jack
while the trailer is hooked to the car. It also helps when you have access to
a set of race ramps and drive the car on.The first time i did it by myself without help i would move up about 3 feet and check my clearance and then move up again. I only did it a few times as i had to sell the trailer(no space) and just drove to the track.
1990 white / black # 2546
one of a few auto EQ 4l8OE ZR-1'S
aafc is offline   Reply With Quote
Old 06-23-2019   #4
cbaclawski
Someone more knowledgeable than me will probably have 10 reasons why NOT to do this, but:
I drilled about a 1" hole in the center of the black plastic lower air dam, and pulled both ends of a nylon strap through the hole from the back around the frame brace that is behind there. I attach my tow hook to both ends of the loop (strap has loops on both ends) and pull it right up.
I have a zip tie loosely through the loops and around the air dam so it can't pull back through the hole when not being pulled, and doesn't put any pressure on the air dam.
Take it for what it's worth...
cbaclawski is offline   Reply With Quote
Old 06-24-2019   #5
Vettemann98
Vettemann98's Avatar
I use a low profile V strap with 6ft legs and cluster hooks on end. I drive up ramps maybe halfway. Attach j hooks to tow points on ether side right behind wheels. The winch wire attaches to V strap and winch up ZR-1. No issues does not rub and stress free. There are 4 attachment points on C4- behind front wheels and just in front of rear wheels. PS I’m actually selling my V strap on EBay as I no longer have my ZR-1.
[SIGPIC][/SIGPIC]
Vettemann98 is offline   Reply With Quote
Old 06-24-2019   #6
Vettemann98
[SIGPIC][/SIGPIC]
Old 06-24-2019   #7
RichS
I used to be able to drive up our open trailer but put 2x12's under the ramps and made sure the tongue was up. Now with the enclosed trailer I have to winch it up. I have the winch mounted in the floor so the cable stays low to the floor. I wrap a long axle strap around the front lower control arm then hook the cable hook to that. I leave it hooked up and then strap the car down with the points behind the front tire, and criss-cross over the rear batwing.
RichS is offline   Reply With Quote
Old 06-24-2019   #8
cadillac531
Originally Posted by Vettemann98 View Post
Attachment 9868
Good info. How much for your strap?
Thanks.
Constantine
Old 06-24-2019   #9
cadillac531
Thanks for the reply. I really didn't want to pull from the control arms and was wanting to get it from the cradle.
I can pass a tow strap through the openings in the front on either side of the radiator support and can grab the cradle. It'll be above the chin spoiler so it shouldn't give me further problems in winching the car up.
As for tying it down, I was going to pass the straps through the wheels using the protective sleeves in front and rear.
Constantine
Old 06-24-2019   #10
cadillac531
Constantine
