Old 04-30-2019   #1
Weeberone
Default Code 41 = new ECM?
Ok. Washed the car the other day and when I started it after it was idling really high about 2000 rpm and didn't have any power. The fan comes on right when I turn the key even before the engine is started. The ccm code on the Speedo says 41 both current and stored, even after clearing. I can got no ECM codes (by grounding A and B) the light in the DIC doesn't even light up. Code 41 means a loss of communication between the ECM and the CCM
My question is will the car still run fine with a good ECM and a bad link between the CCM or is my ECM fubar?
Weeberone is offline   Reply With Quote
Old 04-30-2019   #2
Default Re: Code 41 = new ECM?
Fans coming on and crap running suggest ur in default or limp home mode.
I would pull BATT neg. then see about re-seating the prom in the ECM.
Old 04-30-2019   #3
Weeberone
Battery reconnect did nothing. I'll try the prom next
Old 04-30-2019   #4
G8nightman
G8nightman's Avatar
Sounds like you wet something.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 04-30-2019   #5
Weeberone
Yeah, my pants when I thought of what it'll cost to replace, let alone even finding one!
Old 04-30-2019   #6
G8nightman
G8nightman's Avatar
Ecm are not cheap that is if you can even find one.
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 04-30-2019   #7
Ccmano
Worst case Haibeck can have it rebuilt. I seriously doubt that’s the issue though. Did you wash the engine? In this case its more likely a connector somewhere.
H
Ccmano is online now   Reply With Quote
Old 04-30-2019   #8
reseat the connectors on the ECM, there was someone here who had that issue with bad pin connection to the ECM..
Old 04-30-2019   #9
Sometimes its just a matter of a bit of corrosion that needs some removal.
Old 04-30-2019   #10
Weeberone
Ok. So after sitting over night and reseating the PROM and 4 connectors to the ECM, it seems to be talking with the CCM again. No more CCM code 41 and "Err" at number 4.
The fan stays off with the engine off now, but when starting there is still a high idle and now the check engine light comes on, which it wasn't doing before. The CCM gives a c12 code, but the ECM gives a code 14 "coolant sensor high temp" and a 41 "cylinder select error"
When I erase these codes and start the car it sounds fine for about a couple seconds the the check engine light comes on and the idle increases and it shows the same 2 codes.
Any suggestions?
