03-31-2019 | #1 |
WTB 1990 Stock Chip
Want to buy a 1990 chip that I can change the program. Want to keep the original chip as is. Need one to program fans so the car runs cooler. Thank you,
Tom Sent from my SM-G950U using ZR-1 Net Registry mobile app |
03-31-2019 | #2 |
Re: WTB 1990 Stock Chip
Is there a part number for a ‘90 chip? The chips are different at some point. Don’t know if I would have a ‘90 chip or how to identify it.
Give me a shout if no one has one. Ted |
03-31-2019 | #3 |
I might have a spare I could sell, I know I have one extra, let me see if I have a second
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
03-31-2019 | #4 |
Why not obtain a chip from Marc Haibeck ( Zr-1 Specialist)? It piggybacks on your original Chip so orig. is maintained.
03-31-2019 | #5 | |
http://www.jerrysgaskets.com/eprom-p...on-90-95-14d1/
03-31-2019 | #6 | |
04-01-2019 | #7 |
I did not think Marc still used the adapters. I thought he found they would work loose over time as you could not secure them. I found the same issue with one on my ZR-1
04-01-2019 | #8 |
Jeff: Did not know about the adapter situation. Thanks for the update.
04-06-2019 | #9 |
Are you still looking or did you find this so I can close it ?
04-06-2019 | #10 |
I found one of my spares, one more place to look.. are you having Marc make one for you?
