![]() Join Date: Aug 2004
It gets really confusing. Not sure what to do. Doing the HPDI at BG and trying to figure out should I do just the pads Mark Horner recommended, or new rotors and pads, or some type of front brake upgrade kit that includes calipers. Has anyone done the C5 front caliper upgrade kit and if so was it worth it?
91 Turquoise Metallic Haibeck 525 #0134 |
![]() Join Date: Aug 2006
Depending on the time period, some have upgraded to C5 Z06 front calipers. Later was followed by C6 Z06 fronts and rears. Still others have done Wilwood calipers and rotors.
It really depends on what your ultimate goal is. |
I read a little about this and was thinking c5 z06 because they offer plenty braking but at way more afforable than new c6 parts. Have not priced used c6 z06 parts but im sure good deals show up time to time.
Yeah it's like deciding the best way to go and that ultimate goal. But you don't want to waste money or do something twice. I was just talking to Marc Haibeck about what fluids he used in my car. I asked him about that C5 front caliper upgrade kit. He said you get a bit more but it's marginal. He told me you have to go with the larger 14 inch brake rotors to get noticeable improvement. But that means you have to of course go with larger wheels. He said I could go with a good set of performance pads and the two piece Wilwood rotors. I would like to go with a set of larger wheels down the road. So the rotors and pads might be best for now.
#5 | |
It was all Phil's fault! ![]() ![]() |
![]() Join Date: Jan 2010
If you’re gonna turn into an HPDE junkie go for the fancy brake option.
If not, good pads, Hawk HPS or ?, and a real good brake fluid flush and bleed should see you thru. |
#7 | |
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
This is what i want to do ^^^ one day...
#9 |
![]() Join Date: Jan 2006
#10 | |
Start with good pads, ensure the system is performing at the same level as when it was new, and introduce a high-quality brake fluid with a good flush. Often, people will find that even on well-maintained cars, the system deteriorates over time, so slowly that it is not noticed. Bringing everything back to stock function, along with modern pads and fluid, will likely surprise you with how good the stock system really is. I did this on one of my Alfas and the result was amazing. New hoses, rebuilt master, rebuilt calipers, modern pads and a solid race-quality brake fluid gave me brakes that grip like death. |
