Old 03-19-2019   #1
Subfixer
Subfixer's Avatar
Default Connecting rod bolts
I've got a light knock that I hear around 2000 -2500 rpm that's driving me nuts. Above that rpm, there's too much other noise for my 1/2 deaf ears to hear it.
Not sure what it is, but I want to pull the rod caps and check the bearings. The last owner lost an oil cooler hose, but I don't know how far the car was driven after the hose let go.
Anyway, since the rod bolt torque is so many ft/lbs plus 1/4 turn (or something like that), I'm wondering if the stretched bolts are one time use and should be replaced.
Thanks in advance...
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 03-19-2019   #2
Default Re: Connecting rod bolts
Is it a consistent knock? Do you here it at lower rpm? Have you checked your Dual Mass flywheel? Those will make the motor sound like it it knocking.
Does this happen when the motor is cold? Warm? Both?
Old 03-19-2019   #3
BigJohn
BigJohn's Avatar
Tensioner?
Old 03-19-2019   #4
Subfixer
Subfixer's Avatar
Knock is consistent either cold or hot.
Driven about 1000 miles since I bought the car, hasn't gotten any better or worse.
Only hear it at lower rpms, 2000-2500-ish, only during acceleration or under load. At higher rpms, there's too much road noise to hear it.
No knock while steady cruise, coasting or slowing from what I can hear.
No knock at idle.
Old 03-19-2019   #5
32valvZ
32valvZ's Avatar
Can you capture the sound on video?
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 03-19-2019   #6
Subfixer
Subfixer's Avatar
Originally Posted by BigJohn View Post
Tensioner?
Don't think so. Quiet at idle or revving in neutral.
Only under load/acceleration.
Old 03-19-2019   #7
Subfixer
Subfixer's Avatar
Already tried the video thing. Phone can't pick it up while driving. It's not that loud.
Sounds like a quiet version of a single rod knock.
Old 03-19-2019   #8
Stethoscope might help to pin point location of noise too? Might be there at idle just not heard
Old 03-19-2019   #9
RussMcB
Seems like the rod knocks I've heard could be heard even at low RPM's. But (fortunately) I haven't heard many.
Old 03-19-2019   #10
Subfixer
Subfixer's Avatar
Yup, already tried the Stethoscope, both at idle and higher rpm.
Couldn't hear anything without the engine loaded.
So, back to the original question..... are the rod bolts reuseable, or do I need replacement bolts?
