Old 03-17-2019   #1
tnova
Default Crankcase Vent Cover Tube Loose
To install the driver's side injector housing I was removing the vent hose from the crankcase vent cover. The hose clamp was completely loose and when I put a rotation and pull motion on the hose, the tube came out of the vent cover instead of the hose separating from the hose. (The hoses are original and very hard. New ones on order from Jerry's)
The tube wasn't damaged. There was a sealant or adhesive around the tube portion that fits in to the cover. I've totally cleaned it up plus any that was in the bore on the cover.
Question: What sealant or adhesive should I use when I reseat the tube in the vent cover?
Tony - Tnova
tnova is offline   Reply With Quote
Old 03-17-2019   #2
secondchance
Default Re: Crankcase Vent Cover Tube Loose
Tony - Tnova
I would, after through clean and degreasing maybe even scuff lightly with 400 grit sandpaper, someone may object but, use epoxy or JB weld myself.
Old 03-17-2019   #3
Jagdpanzer
Jagdpanzer's Avatar
Or use some Loctite 620
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-17-2019   #4
mgbrv8
Hey Tom
If you look at my album of pictures you see how I dealt with it about half way through the pictures. Hope it helps
Dave
https://www.facebook.com/zr1netregis...60115440860615
Tony - Tnova
Old 03-17-2019   #5
Same thing happened to me. I used Loctite 262, let set overnight. All worked like new. Phil is correct for Loctite 620 being the best for the application, I just didn't have any on hand.
Old 03-17-2019   #6
Corvettes White
Is this the answer? I "found" these books not to long ago. Had a reason to open them up.
George
Corvettes White is offline   Reply With Quote
Old 03-18-2019   #7
tnova
To all, thanks. This is a great forum. I've got 620 on hand and will do this morning. I wish my "Brand P" racecar buddies where as knowledgeable and helpful as the LT5 crowd.
BTW, for those who have asked, yes, I do have a Nova, thus the nickname. '72, old school set up for driving to the strip for test-'n-tunes. Not as cool as my ZR-1 though.
Tony - Tnova
Old 03-18-2019   #8
tnova
George,
You have the factory assembly book? OUTSTANDING!!!! Preserve them like a library archive. Don't ever let them leave the group.
Tony - TNova
Old 03-18-2019   #9
Tyler Townsley
Friend recently gave me a complete set of c-4 factory assembly manuals including one for the 1983. The 83 one may be the only one in existence according to another friend who has been looking for one for over 10 years.
Tyler
Old 03-18-2019   #10
Corvettes White
George,
Tony - TNova
Yes,. Got lucky. It is a latter version with a lot of updated pages. Maybe 600 pages total.
Good luck with your project.
Tags
crankcase vent cover, hose, tube
