Old 02-28-2019   #1
Default Cam Sensor Questions
Few questions. Where do we buy the replacement now? Jerry?
Also for those of us who had a cam sensor failure what were the symptoms?
While I don't believe mine is having issues, I was looking into something else and was curious on these particular symptoms
any input?
THANKS
Old 02-28-2019   #2
Young1
Young1's Avatar
Default Re: Cam Sensor Questions
Do a search. Plenty on here about. You will get a code 31 if I remember correctly. In my case it would intermittently just stop running! A member here builds a replacement sensor. I have the prototype and it has been fine for 18 months now. As you have discovered the cam position sensor is now NA.
Steve Young
Second Owner
SOLD
SOLD
Old 02-28-2019   #3
Alternative Camshaft Position Sensor
Old 02-28-2019   #4
Dynomite.. end of that thread he says he turned it over to Jerry.. does anyone have a PN for Jerry's website. I cannot find it in a search..
Old 03-07-2019   #5
any input?
THANKS
-=JEFF=- all I had was a SES code 31 that would consistently set in the DIC. I replaced the sensor and the Code 31 went away. GC
Old 03-08-2019   #6
Is Jerry making the sensors or will Phil make some more sensors. For a week or so the sensors Phil Made sold like Hot Cakes
Old 03-09-2019   #7
No idea
Old 03-09-2019   #8
I think Phil will make one if needed..
Old 07-25-2019   #9
Jetjock
Jetjock's Avatar
I’m having a hard time getting the new cam sensor back in. Any tips on getting it back in. Also, what about the shield? Leave it or put it back on?
Thanks
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Jetjock is offline   Reply With Quote
Old 07-26-2019   #10
Jagdpanzer
Jagdpanzer's Avatar
Rub a little motor oil on the bore entry in the head and on sensor o-ring and it should push right in with a slight twist. Shield should be put back on again.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
