Old 02-19-2019   #1
aafc
aafc's Avatar
Default injection housing leak
After a hard drive i noticed some oil on the right side of inj housing. It looks like there is a leak from the gasket. Time to pull housing and replace the
gaskets. Should i replace the o rings on my injectors while i'am in there.
Injectors are from FIC installed some time ago. I ordered new housing
gaskets and plenum gaskets, but forgot to order o rings. Do i replace
only the primary or do all of them.
Thanks
aafc is offline   Reply With Quote
Old 02-19-2019   #2
Default Re: injection housing leak
Thanks
John,
FIC injectors come with new, Viton o-ring seals, except for the primary injector lower o-ring seals(8), Jerrys Gaskets PN 10067600-V. If you are not sure the o-rings you have presently are Viton, I recommend replacement. The rest of the o-ring seals are OK for re-use provided they are not damaged.
Lightly lube all of the o-rings with motor oil before re-installing. Do not use silicone grease.
Old 02-19-2019   #3
Ccmano
Ccmano's Avatar
Jerry,
I’m curious why you recommend not using silicone grease?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 02-19-2019   #4
Originally Posted by Ccmano View Post
Jerry,
H
Silicone will damage the O2 Sensors.
Old 02-20-2019   #5
Silicone will kill the catalyst in the converters.
Actually Jerry my understanding is that silicone kills the O2 sensor, not the converter.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-20-2019   #6
You are right Dom, my mistake. I knew that but it just didn't come forward when I was recalling the issue with silicone. One of those symptoms of age.. Thanks for calling it to my attention.
Old 02-20-2019   #7
No worries. Happens to the best of us.
Old 02-23-2019   #8
BigIke
Replaced mine, 5 years overdue, tighten our replace the evac cover bolts/gasket, it will be loose.
Get Jerry's core plugs and deep-6 the secondaries!!!
Sent from my SM-G960U using ZR-1 Net Registry mobile app
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
