Old 02-19-2019   #1
Weeberone
Default Any of the recommended transmission fluids red?
So I’m changing the fluid in the transmission with some Redline MTL (which is a golden yellow like most lubes) and the fluid that drained out was red. Are any of the other recommended fluids red in color? It looks a lot like ATF.
Sent from my iPhone using Tapatalk
Weeberone is offline   Reply With Quote
Old 02-19-2019   #2
Karl
Karl's Avatar
Default Re: Any of the recommended transmission fluids red?
I don't have any to look at but I really though the Redline synchromesh fluid was/is red.
When I changed my VSS red fluid came out and the fluid was recently changed.
Either it was red or I am overworked and need a vacation.
Old 02-19-2019   #3
Weeberone
The Redline MTL Syncromesh fluid is a very light yellow-pink colour. This a a very dark red. Also, how sparkly should it be?
Old 02-19-2019   #4
Karl
Karl's Avatar
Sorry, I used Amsoil and not Redline.
https://www.ebay.com/i/283371252387?chn=ps
The Amsoil is red.
Good luck!
I am about to plan a vacation.
I have Valvoline in the motor, Amsoil in the transmission, and Royal Purple in the Dana 44.
Old 02-19-2019   #5
George Maz
Amsoil Synchromesh is not red, more like honey yellow oil. I'd consider a repeat fill, run trans, and flush to get out that ATF. You probably could accomplish it safely on the lift with low speed wheels turning 1st gear, 3minute run time.
Sparkles are brass syncro material which you want to drain suspended in oil, non-ferrous so a magnet won't help.Amsoil.jpeg20170423_001210.jpeg20170423_002116.jpeg
Sent from my SM-N920V using ZR-1 Net Registry mobile app
George Maz is offline   Reply With Quote
Old 02-19-2019   #6
Redline Heavy Shockproof synthetic gear oil is as you see below...
File Type: jpg Redline Heavy Shockproof synthetic gear oil.jpg (246.6 KB, 44 views)
Old 02-19-2019   #7
Karl
Karl's Avatar
Guess I am color blind. Looks red to me!
That is gear oil. Not transmission oil.
Old 02-19-2019   #8
Ccmano
The Red Line Heavy Shock Proof is generally used when a light weight flywheel has been installed to dampen transmission rattle. I believe Haibeck recommends it for that purpose. He provides an excellent guide here.
http://www.zr1specialist.com/HAT%20W...ns/ZFS6-40.pdf
H
Old 02-19-2019   #9
George Maz
Anybody using the Redline Shockproof in their rear-end differential?
Old 02-20-2019   #10
Mystic ZR-1
Mystic ZR-1's Avatar
I have Amsoil Severe Gear 75w-110 with 4.10 Yukon gears.Attachment 9108
Do ya need the LS additive aka: “whale oil” with
this stuff?
Mobil 1 has it “built in”
Big John: Save the Mystic Seaport/Charles W Morgan
comments... pretty sure they don‘t sell it in the gift shop.
