Does anyone happen to know how much the factory oil cooler flows? My LT5 is going in a different car and did not come with the factory cooler. I have a really nice oil cooler from a previous project that originally came from an airplane but has -8 fittings. I would like to flow the cooler I have to see if it would be a restriction compared to the factory cooler.
#2 | |
![]() Oil Filter Adapter Functions 1 Oil Filter Adapter Functions 2
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
So basically what I am reading from that is that even if the cooler is a little restrictive the engine will still see full oil flow because it will bypass oil around the cooler if it senses a restriction there.
#4 | |
Oil Filter Bypass Valve serves that function for restrictive Oil Filter.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-09-2019 at 11:54 AM. |
That makes me feel a lot better about using my oil cooler and saves a decent amount of money on buying a new one.
