Old 01-28-2019   #1
Young1
Young1's Avatar
Default Sway bar link bushing install, frustrated in FLl
Ok it is night 2 and no luck getting the pulyurathane bushing into the sway bar while it is on the car. Yes I removed the thin metal sleeve. Yes all is lubed with supplied grease. I need a proven technique that works!
Steve Young
Second Owner
SOLD
SOLD
Old 01-28-2019   #2
Karl
Karl's Avatar
Default Re: Sway bar link bushing install, frustrated in FLl
When in doubt go to YouTube.
https://youtu.be/jhM0BHQ2STU
Good luck!
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 01-28-2019   #3
Ccmano
Ccmano's Avatar
It will require a press of some sort. A big vice or a C clamp style ball joint tool will do the job too. Just did my entire suspension but I had a 20 ton Harbor Freight press.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 01-28-2019   #4
Young1
Young1's Avatar
Looks like I need to pick up a large c clamp. Thank you gentlemen.
Steve Young
Second Owner
SOLD
SOLD
Old 01-29-2019   #5
Flyman 27
Flyman 27's Avatar
The ball joint tool sold on ebay has what you need in the kit. Kill 2 birds with one stone. It has an oversized "C" clamp plus the adapters for ball joints. You would then have the tools to R+R ball joints for the future.
https://www.ebay.com/itm/ABN-Ball-Jo...5b5c:rk:4:pf:0
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 01-29-2019   #6
JFFerner
Some auto parts store ie Auto Zone have loaner tool kits. Just provide a credit card as a deposit & get refunded when tool is returned.
JFFerner is offline   Reply With Quote
Old 01-29-2019   #7
Young1
Young1's Avatar
I got them in holding a socket the bushing and the C clamp all in one hand. A bit of fumbling but didn't take too long thanks for the help.
Steve Young
Second Owner
SOLD
SOLD
Old 01-29-2019   #8
Ccmano
Ccmano's Avatar
Good work, just wait till you have to do the rest of the bushings. I paid less for the press than what the machine shop wanted to press the old bushings and ball joints out and in.
H
Old 01-29-2019   #9
Young1
Young1's Avatar
Those little ones were my last. I took the bones and the bars to a friends shop and pressed them out there. I am just doing the rear at this time. When I do things myself I buy the best parts and needed tools. Saves a bunch.
Steve Young
Second Owner
SOLD
SOLD
Old 01-29-2019   #10
32valvZ
32valvZ's Avatar
I have almost all the rear done... I just need to install the thrust arms I think they are... the big ones on the bottom that go from the knuckle to the center section.... bushings are all in, just need to swap arms...
I been skeered to tackle the fronts... I have all the ES bushings sitting on the bench too.... I have a 12 ton press that should work... i hope... I wanted this done by the spring... I hope I can muster up the time & courage to get it done...
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
