Old 01-28-2019   #1
ZWILD1
ZWILD1's Avatar
Default Radiator recommendations ?
My son and I plan on making the trip to BG this year and I plan on installing new hoses and was thinking about replacing the factory radiator with a larger aluminum one. Who makes a good radiator to drop in? I replaced the radiator on my first ZR1 and my 96 LT1 car with a factory style but not worried about the car looking original.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 01-28-2019   #2
secondchance
Default Re: Radiator recommendations ?
I installed Dewitt Pro Series which has two rows 1" pipes. Much better quality and no longer worried about plastic side tanks busting on OEM radiator.
https://www.dewitts.com/collections/...minum-radiator
Old 01-28-2019   #3
Dewitt
Old 01-28-2019   #4
Jagdpanzer
Jagdpanzer's Avatar
Dewitt has their annual 15% off sale still going on until February 2nd.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-28-2019   #5
Karl
Karl's Avatar
I purchased a DeWitt radiator on sale over the holidays along with silicone hoses and a new heater core.
Old 01-28-2019   #6
RussMcB
I went with Dewitt, too. I'm happy with the end result but it was more work than I expected. Afterwards, though, you'll have great peace of mind, especially if you plan to do some laps at the track.
Maybe budget extra time in case you need to walk away from it for a while and take a break.
In other words, don't do it on the Wednesday night before you leave for BG. :-).
Old 01-29-2019   #7
Ron Davis, Fluidyne, Other Multicore Aluminum......Just to add some choices
All perform perfectly
Dynomite is online now   Reply With Quote
Old 01-29-2019   #8
ZWILD1
ZWILD1's Avatar
As I remember the OEM style went in pretty much straight forward. Is the Dewitt more difficult? The thing I hated was changing out the hoses going to the thermostat. I ended up going to Sears back in the day and buying a remote hose clamp tool to make dealing with the factory style clamps easier but it was still a pain.
Old 01-31-2019   #9
ZR1North
I too went with the DeWitts that others mentioned. Marc did the replacement when he did the 510 pkg. I know he used my original GM hoses. The unit comes with a spacer bar that must be installed because of the rad thickness, but it is easy to install and does not diminish the underhood appearance. That's where my research led me, and I am extremely happy with the product some five years in.
1991 ZR-1 (SN666) - Haibeck 510; 410s, Corsa, SW Headers; Hurst SS; DeWitts Rad; RC Injectors; LEDs throughout; `93 MF Sawblades
2016 Z06 - Stock
1971 Stingray 454 LS5 - Sold
ZR1North is offline   Reply With Quote
Old 02-02-2019   #10
BlackZR1
BlackZR1's Avatar
Thanks for the tip, just placed my order.
Plastic tank is weeping at the crimped joint.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
