Old 01-06-2019   #1
tommy
Default Timing chain guide
Hello guys,
A few days ago I removed camshaft cover and saw this :
This is number PN10122172 in Jerry's gaskets :
Anybody know is it possible to change this timing chain guide without removing the engine?
tommy is offline   Reply With Quote
Old 01-06-2019   #2
Default Re: timing chain
You are referring to the guide not the chain correct?
Old 01-06-2019   #3
tommy
Yes, Jeff, you`re right. Sorry for my mistake, I corrected it.
Old 01-06-2019   #4
Looking at the pictures I am guessing you will need to have the motor out, but I don’t honestly know.. hopefully Pete, Marc or someone that has done something with the guides will chime in
Old 01-06-2019   #5
tommy
I`m afraid about this option, I hope somebody does this without removing the engine. Because I can not leave it as it is.
Old 01-06-2019   #6
Default timing chain
Remove engine...……..
Dynomite is online now   Reply With Quote
Old 01-06-2019   #7
Ccmano
Sorry to tell you the engine will have to come out. While not impossible to do in the car the effort involved is such that removing the engine is actually easier. It will require retiming the cams. To my knowledge Marc Haibeck tried to time cams in the car and found it problematic.
H
Old 01-07-2019   #8
tommy
Default Re: Timing chain guide
Thank you for this sad news, so i must try to go out with the engine
Wysłane z mojego VTR-L29 przy użyciu Tapatalka
Old 01-07-2019   #9
How many miles on that engine?
Actually it is good news as you caught it before serious damage
What got you to remove Cam Covers (engine installed)? That alone is not so easy but I have done that and have even removed Heads Engine in car but like Hans suggests....You cannot really do a good job timing the engine without engine removal.
Chance to do some serious reconditioning possibly replace all 4/6 chain guide facings (two on cam covers).
I have no idea what would cause a chain guide facing to break off but it happens (rarely) and I think Jerry of Jerry's Gaskets has insight as to why that might happen (Marc Haibeck I am sure has seen it before and would also have insight). There are two issues (chain guide facings breaking and chain guide facings wearing).
It is the inspection of the Chain Guide Facings that is difficult and some inspection of the chain guides is possible through the passenger side oil cap. Marc has also addressed the Chain Guide Facing Inspection issue on his web site.
I have been trying to figure out the longevity of chain guide facings but seems to have considerable variation possibly depending on type of engine oil used, environmental temperatures, and other variables (maybe firing up the enigine in sub zero temperatures would contribute to chain guide facings breaking). A figure of 150,000 miles has been mentioned but then I recall there are 200,000+ mile LT5s with original chain guide facings
Marc Haibeck and Jerry are two individuals (and others that have dismantled high mileage engines) that would definitely have the experience to expand on that issue of chain guide longevity
Old 01-07-2019   #10
Jagdpanzer
Jagdpanzer's Avatar
As plastic chain facings age they tend to become brittle and break a lot easier. Recommend also inspecting the cam chain tensioners to make sure they are functioning correctly.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
