Old 12-28-2018   #1
Young1
Young1's Avatar
Default Injector Identification needed
Plenum is off and neither Marc's site nor Stickies indicates. Please identify what I have installed. They all check out ohm wise.
Green band installed in secondary
3226 5235366
Red band installed in primary
2203 5235357
First owner did replace originals but could not tell me with what. Probably work was fine st a dealership. Could these be 93-95 MY injectors?
Steve Young
Second Owner
SOLD
SOLD
Old 12-28-2018   #2
Ccmano
Default Re: Injector Identification needed
Can you post a photo?
H
Ccmano is online now   Reply With Quote
Old 12-28-2018   #3
Ccmano
From the numbers they are Rochester MPI injectors that are original equipment on the 90-92 engines. You can find them listed here...
http://teamzr1.com/injector.htm
H
Old 12-28-2018   #4
Young1
Young1's Avatar
Does that mean that these will fail because of alcohol? Or were these part numbers upgraded to resistant materials?
Steve Young
Second Owner
SOLD
SOLD
Old 12-28-2018   #5
secondchance
Others may disagree but I have a 94 and it’s injectors failed way back when. Was it alcohol? I don’t know.
Old 12-29-2018   #6
Young1
Young1's Avatar
I am trying to track down the slight knock and slight rough idle. The injectors check out with ohms and so do the coils. I am replacing the coil's since they are originals.
Steve Young
Second Owner
SOLD
SOLD
Old 12-29-2018   #7
Ccmano
Ohms is only half the Issue. Spray pattern is the other. Check for a local place that can check the flow. Problem is it gets a little pricy to have them checked. $10 to 20 per injector is not unusual. It’s almost worth it to just replace the injectors. Accels and FIC’s are $600 -700 a set of 16. While your at it Ohm out the wires, replace the plugs and do a compression test. At sea level compression should be ~200-215 psi.
H
Old 12-29-2018   #8
Well as we realized during my own recent check of injectors, Marc Haibeck will flow test injectors for $100. And the shop I used also charged $99 for flow testing and inspecting all 16 injectors. In my case, it turned out to be well worth the money ultimately leading me to replace all of them w FICs.
