Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Cleaning and Waxing
Old 12-14-2018   #1
Vette73
Default C quartz prep..
Winter here in the northeast...Recently been reading about the benefits of ceramic coating ( c quartz)..
My car is black....Thinking of doing this come March....Anyone ever use C quartz?
What exactly are the steps leading up to applying the C quartz.....There's a few on you tube and it seems like a ton of prep...
Vette73 is offline   Reply With Quote
Old 12-17-2018   #2
DarkAngel
DarkAngel's Avatar
Default Re: C quartz prep..
Hello, ive done my 'Z with C quartz in may
yes it's a lot of prep
first you need to wash the car properly and use a clay to remove every imperfection stuck in the paint
then you need to polish the car with different level of abrusive to get rid of all defect (swirl, phantom, micro scratch, etc ...)
then you need to put 1,2 or 3 pass of c quarz
avoid direct sunlight of course and buff it with a good and heavy microfiber towel (it's really important to have a good one)
then let the car stay for 24H away from rain (it will leave drop and it will stuck in the coating)
for regular wash, you need to use a special shampoo designed for clear coat and a reload spray (like car pro)
a very good video that resume all of this :
https://www.youtube.com/watch?v=byKcYsEyWGk
so, if you can find a company that does it for cheap, it will save you a lot of work
DarkAngel is offline   Reply With Quote
Old 12-17-2018   #3
Vette73
Hey thanks....Yes seems like a lot of work..Plus I have no door on my garage...
Stay tuned....
