12-08-2018 | #1 |
90 Z cranks but will not start
I drove it to work, would not start to go home. Got a new battery, still cranks but will not turn over. Any ideas?
KWood 1st Time Owner 1990 ZR-1[SIGPIC][/SIGPIC] |
12-08-2018 | #2 | |
Why a new battery? the starter turns the engine over but engine does not fire? Check INJ1 fuse. Sent from my iPhone using ZR-1 Net Registry
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-13-2018 at 05:19 PM. |
12-08-2018 | #3 |
Re: 90 Z cranks but will not start
Fuel Pump?
12-09-2018 | #4 |
Yes. Battery was low, thought it did not have enough amps. I checked the fuse, it looked ok. Fuel pump was my next guess. Roll start would not work then, correct?
12-09-2018 | #5 | |
This is confusing. The starter spins the engine or not? I think you're saying the engine spins but does not start. Quick check is to spray starting fluid in the throttle body and crank the engine. If it fires and stops, you have a fuel problem. If it doesn't fire, you have an ignition problem. |
12-11-2018 | #6 |
Correct. Will do that. Thanks. Sorry, for the confusion.
12-11-2018 | #7 |
Follow the FSM diagnostic tree to figure this out. Otherwise it’s just a shot in the dark. There are multitude of things that could cause this.
H
12-13-2018 | #8 |
Thanks for the info. Starter fluid started the car, but did not keep it running. Guess I’m looking at a fuel problem.
12-13-2018 | #9 |
Now you can start going down the Chart A-7 posted above.
Have you checked the fuel pressure with a gauge? |
12-14-2018 | #10 |
No. I bought a couple of the suggested fuel pumps and am sending to the local Vette mechanic to let him run the diagnostics. Would love to say I’m a DIY guy, but I don’t have that equipment. Or a garage, after the divorce. But, I still have my Z, so that’s something.
