Old 12-05-2018   #1
BigIke
Default Loud popping on take off, screeching when loaded up.
Hey y'all, got a loud pop that you can feel through the car when taking off from a stop, also turning under load. Also has a sound like sketching, or rubbing when I load the drive line with anything more than a little throttle. Sounds a lot like a brake pad tattle tale touching the rotor, except it gets louder with more throttle...
With the car in gear and the e-brake off, there is a popping noise when I rock the car back and forth. Got up under it and it sounds like right side u-joit or maybe the differential.
The sketching under load points to a diff going out, but I don't know if a half shaft u-joint will do the same thing.
Anyone had this issue? Help troubleshoot?
The Juan is going to be down for awhile. Going to install new u-joints in the right rear, and a new hub, have had the parts for awhile. Also had another intake backfire, when I pull the upper plenum this time I'm going to replace the lower gaskets, got a vacuum leak there sucking in oil and making me smoke.
Jay
Sent from my SM-G960U using ZR-1 Net Registry mobile app
Old 12-06-2018   #2
Default Re: Loud popping on take off, screeching when loaded up.
Old 12-06-2018   #3
BigIke
:happier1:
Old 12-06-2018   #4
Jagdpanzer
Jagdpanzer's Avatar
Sounds like either your bearing hubs or half shaft u-joints, or both, are well on their way out. While at it also be sure to check out the differential.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
