Old 12-02-2018   #1
jss06c6
Default Improper Pilot Bushing Installation
Here's a textbook example of improper pilot bushing installation and the damage it causes. The oilite bronze bushing was not set to correct depth and was contaminated with grease. Not only was the pilot bushing shot, the input shaft tip is destroyed. Significant vibration upon acceleration from 1500 rpm felt in shifter as well as the floor. Flywheel (Ram Aluminum) was also damaged (now resurfaced and balanced) along with the throwout bearing (rebuilt).
The input shaft was continuously riding on the face of the pilot bushing!IMG_20181202_070651.jpgIMG_20181129_183809.jpgIMG_20181129_183649.jpgIMG_20181130_091752184.jpeg
Old 12-02-2018   #2
Ccmano
Ccmano's Avatar
Default Re: Improper Pilot Bushing Installation
Improper bushing seating depth and use of grease when none should have been applied....
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 12-07-2018   #3
jss06c6
Properly set with FW machined and balanced..[ATTACH][ATTACH][ATTACH][ATTACH]
Old 12-07-2018   #4
H
Seating depth, I can understand. But, greasing the broze bushing (pilot bearing) resulting in THAT particular failure - considering those bearings are impregnated with lube (are they not?) out of the box?
I'm seeing the damaged(?) input shaft and bearing, and not intending to be casting dispersions, but I am a shade skeptical of the diagnosis. I know I'm setting the stage for ridicule, but I'd want to know more...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 12-07-2018   #5
I concur...…..Those impregnated bushings (I use needle bearing bushings on ALL Zs) do not need grease. Matter of FACT...…From a different Pilot Bushing Failure analyzed by ZF.Doc…...
From the ZF.Doc
I replayed the video about twenty times. It sounds like the pilot bushing is
compromised. Install GM fluted pilot bushing (GM P/N 10125896). WARNING: Applying grease in an oil-lite type pilot bushing will cause the pilot bushing to fail within the first one percent of its normal life expectancy. Although very dry looking straight out of the bag, the oil-lite type pilot bushing is infused with enough oil to lubricated the input shaft pilot tip for the entire service life of the clutch. Why not just install a pilot roller bearing instead? When a pilot roller bearing fails, the input shaft pilot tip will be compromised requiring removal of the input shaft for pilot tip repair or replacement of the input shaft.
I seems to me that rather simple measurements would prove exactly how far the transmission nose penetrated the bearing. Maybe the Transmission was loose from the Bell Housing
It appears that the marks on the Trans tip would indicate the Trans was seated well into the Pilot Bearing
All sorts of possibilities
Ridicule ???? ……….You mean Debate on this Forum
What we have to do is load our photos into our Forum Albums (Registry or CF) so we can see what is going on
Old 12-07-2018   #6
As I study the photo of the input shaft to the extent the photo allows, there was GALLING occurring in 3 distinct bands along the shaft. Why not along the entire contact length between the bearing and the input shaft??
You don't get galling between steel and bronze. There has to be a third element (steel) contaminant in the mix. And, when you look carefully, is that a bit of the grease on the end of the input shaft? Note that it no longer looks to be viscus, and it appears to be impregnated with metal filings.
I'm intrigued...
Tell ya what: Not being able to inspect the clutch components directly, a real forensic analysis is difficult. That said, and this is just a SWAG mind you, but something else was going on with that installation - i.e., the REAL reason CONTRIBUTING to the demise.
Again, I'm only seeing the pictures. I could be wrong, but there appears to be waaay too much metal filings contaminating that bearing, evident in the "grease" residue. So, I'll toss this in for your consideration, this possible hypothesis:
The grease became saturated with the normal clutch disc (dust) material, true. But, far more important is the metal filings. The combination of the two combined with the grease to form a stiff material, forming a barrier scattered randomly along the input shaft. The metal filings became dammed up and HEAT soon followed.
The bronze bushing then became impregnated with the metal filings that were clumping up along the shaft. That led to isolating the lubricity of the bronze from the shaft, and RED HOT HEAT (also very evident) ensued to the point of initiating the (steel on steel) galling evident from the pictures.
Replacing all the damaged parts sets up a "do over". And, if in fact there IS evidence of metal filings, the cause of that evidence may too have been eliminated. But, I'd really want to run that filing contamination to ground - assuming there ARE significant amounts of such contamination remaining to be found. Unless the cause of the metal filings is identified and corrected, the stage is set for a sequel of the first act.
That's my hypothesis - and worth the price of free internet advice, no doubt. I just don't buy the theory that the grease, because it was used, caused the galling. It may have been a contributing factor, but were there no metal filings, would the galling have taken place anyway?? I doubt it.
90 #1202
Sans secondaries
Old 12-07-2018   #7
I concur...…..Those impregnated bushings (I use needle bearing bushings on ALL Zs) do not need grease but on the other hand I am not so sure adding grease would cause such a failure.
Ya beat me to the "enter" key, my friend!!
90 #1202
Sans secondaries
Old 12-07-2018   #8
An interesting situation and discussion. I tend to agree with Paul that it would seem there must be a source of steel or other strong abrasive to cause all that galling. The shaft is (I believe) case hardened steel and the bushing is bronze, a much softer metal so I would expect that it would not in itself cause the galling, rather the scoring would likely be more pronounced on the bushing itself. Curious to know if you examined the grease for what appear to be metal filings in it (although presumably some of it probably came from the shaft) and whether there was scoring inside the bronze bushing. --Bob
Old 12-07-2018   #9
The marks on the Trans Shaft do not indicate that (Red Highlight Above) but possibly later after considerable use the Pilot Bushing drifted to a greater depth and the Trans Shaft finally was free of the Pilot Bushing.
ZF.doc analyzed a different Pilot Bushing Failure somewhat similar to this Failure in this Thread......and suggests Applying grease in an oil-lite type pilot bushing will cause the pilot bushing to fail within the first one percent of its normal life expectancy.
This was posted by Daryll regarding the
similar Pilot Bearing Failure (not this failure in this thread)...…..
From the ZF.Doc………….
Marc Haibeck specific diagnosis on a similar Pilot Bushing Failure to the one in this thread explains...……
"It is a faulty pilot bushing for sure. What causes a pilot bushing to fail? Grease applied to the inside diameter surface of an oil-lite (oil saturated) pilot bushing is the number one cause for pilot bushing failure. Grease applied in a pilot bushing eventually dries up and clogs the otherwise normally self-oiling pours of the bushing".
See...…………….
Throwout Bearing and Pilot Bearing TIPS
Pilot Bearing Failure TIPS
Paul...…..Please delete my initial suggestion made without checking the -Solutions- thread first which is an incorrect suggestion I was Not so sure about ………."but on the other hand I am not so sure adding grease would cause such a failure".
Again......I use Roller Bearing Pilot Bushings which take a good amount of grease during the installation even though ZFdoc suggests...…."Why not just install a pilot roller bearing instead? When a pilot roller bearing fails, the input shaft pilot tip will be compromised requiring removal of the input shaft for pilot tip repair or replacement of the input shaft". ( I figure the Trans Tip was compromised in the this case with a much quicker failure than one would expect with a roller bearing)
Old 12-07-2018   #10
Interesting topic, 'fer sher'.
That said, and having serviced many a clutch, starting with my part-time job as a mechanic, back in my college dayz, I became slightly paranoid about riding the clutch; either at a stop light or waiting for an opening in bizzy city traffic.
90 #1202
Sans secondaries
