![]() Join Date: Feb 2010
when reinstalling the plenum there are two connectors on the front, which
one goes where? One has BK,YL and GR wire and the other has BK,OR and BL the connectors tabs are broken off so they could be put back reversed. Thanks John Happy Thanksgiving |
while drag racing i had a stumble/miss at the top of 1st gear a around 6500.
happened a few times ,but only when racing. so i pulled the plenum and checked the coils primary 1.2 ohms all ok and secondary's all 4 ok. checked plug wires found # 1 opened ,but it would test good then go open at times. so new wires ordered ,while waiting for the wires i removed the secondary throttle system ,sent chip to Mark for revise calibration to remove the secondary intake port throttle controls. got the chip back ,installed it. then i could not remember which connectors went where on the DIS . emailed Mark he got back to me and said the BK- YL and GR went to the passenger side. so if you brake the tabs on the two front connectors of the DIS and can't remember which one goes where or you did not mark them (like me) and this is for a 1990 ZR-1. not sure about other years. its back together i'll run the tech-1A to check everything is ok. John |
