11-20-2018 | #1 |
Replaced fuel pumps
In the spirit of logging work on my car here in the forums for it's future owner ...
Yesterday I finished replacing the fuel pumps, hoses, clamps, and Y-adapter with Carter's machined aluminum version. This was preventative maintenance - no indication of trouble, but as it's a common area of wear and failure I went ahead and preemptively refreshed everything. Also, it was not that difficult and fairly inexpensive. Car has 23.5k miles. Parts list: 2 x Airtex E3240 fuel pump 2 x Airtex FS1 strainer 1 x Sending unit gasket 1' Gates 27097 3/8" Submersible Fuel Line Hose 1' Gates 27093 5/16" Submersible Fuel Line Hose 2x 3/8" fuel hose clamp 4x 5/16" fuel hose clamp Upon inspection, it was obvious the pumps had never been removed before. Nevertheless, the fuel tank was clean, the plastic Y-adapter was in good shape and not cracked, and the only sign of trouble was a small tear in one of the pump strainers. Replacement was straightforward. I simplified the hose routing for the pumps to eliminate bends that were impossible to duplicate - seems like the factory hoses were shaped a specific way but trying to duplicate the bends with a straight hose would cause a little creasing. Here's the final reassembly: [Update 12/11/18] I had to pull the assembly again because fuel pressure was dropping abruptly after the key-on 2 second pump run. I did not clamp the hoses in the assembly tight enough; in fact I used the wrong size clamps on the 5/16" hoses. Corrected and re-tested.
-Stephen 1990 #2288 Last edited by Reichert; 12-11-2018 at 09:22 AM. |
11-20-2018 | #2 |
Re: Replaced fuel pumps
Good Information with clickable titled links and photo coverage......Thank You Stephen
In "Solutions" (6th Post) under FUEL DELIVERY.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-20-2018 at 03:24 PM. |
05-25-2019 | #3 |
I know this an old post but can you tell me where you got the carter aluminum y adapter.
Thanks |
05-25-2019 | #4 | |
Shoot Carter an email at: ctmachining@gmail.com He will hook you up. Sent from my iPhone using ZR-1 Net Registry
05-26-2019 | #5 |
Thanks.
05-26-2019 | #6 |
08-05-2019 | #7 |
I just replaced my fuel pumps. I disconnected the battery to do so. Upon re-start everything seems OK but the range indicator shows zero even though there is fuel. Pressing reset on the dash button didn´t help. Any ideas? Thanks black90.
08-06-2019 | #8 |
Just a WAG ... The arm is stuck on something, not swinging up and down.
11-09-2019 | #9 |
Thanks for this. Just finished replicating it for my '91, which has been sitting for almost 10 years - #0637 - 85k miles - original owner. Both pumps were seized solid.
The gasket you list above only has 8 holes. My one has 9. Here's the part info - $15 from local parts store: |
11-19-2019 | #10 | |
I also have a high idle problem so going to find that vacuum leak - probably after Thanksgiving 'though. No time right now. |
